97 2.5 TL bolt pattern?
All,
I have to get new rims for my 97 2.5 TL. The reason being is that my dad ran over a man hole going 45mph and destroyed the rear wheel.
Everwhere I look the bolt pattern is listed as 4X114.3. For the mean time I am putting a steel wheel from my 94 Acura Integra and it seems to fit and drive fine. However the bolt pattern for Integra's are listed as 4x100.
I am getting ready to purchase some Honda prelude wheels to replace all four as I am having a really hard time finding just one TL wheel. The prelude wheels are list with a bolt pattern of 4x114.3 so they should work. I just don't want to make the wrong buy.
Was going to put this in the wheel and tire section but it seems to be out dated and listed as "OLD".
Any help on this would be great. Thanks again.
大日本帝国
It's listed as "Old" because there haven't been new posts that you either haven't read, or that were posted in the time since you last visited the site.
In any case, you should be 4 x 114.3, AKA Big 4. Maybe you got lucky and got a Big 4 Integra, because the 96-spec ITR has that bolt pattern. Considering 14.3mm is a rather big difference, and 5 x 112 wheels won't fit on a 5 x 114.3, with only a 2.3mm difference.
Was only the rim damaged? I'd think that going into a manhole at 45 would break quite a few things!
~Cheers~
~Cheers~
I am going to test this weekend. I will take off the wheel from my brother's 94 Integra LS and see if they fit. I know his wheels are 4x100 as I have but civic wheels on them before. I called up my buddy at a honda dealer and he says it shouldn't fit, I called a wheel shop and they said it shouldn't fit. Is this TL some frankinstein lemon?
johnpancakes014
09-27-2015 12:58 PM
