96 TL starting problems.
My 1996 TL has had this problem since I got it in 1997....When I turn the key to start the car, the engine turns but does not start. If I then let off the key and hit it again, it starts beautifully every time. The acura service folks told me, "That's just the way the 5 cylinder engines are." I have a hard time buying into that line of logic.
Is there any ancecdotal info out there that will give me some insight into how I might go about resolving this problem. I love this little car and it has been solid from day one. The starter issue just happens to drive me nuts!
I have a 96 TL 2.5 and mine is doing some of the same things. I have to sometimes put my car in Neutral and start it. I had the ignition switch replaced about a year ago. I have 220,000 on the car. So I won't complain.
I had this problem on my 96 Acura tl 3.2 with 255xxx. Thought it was my fuel pump but end up being my Main Relay that controls the fuel pump and i think the ECU.
It's a $70 part, but cost me $320 cause I thought it was the fuel pump.
Here some info hope this helps
http://techauto.awardspace.com/acurarelay.html
If you'll notice when no-start occurs, if key is in ON position are the Alt & Check Engine lights On? If a blank panel, the keyswitch may be opening and disabling power to the ignition, disabling starting. Easy fix to replace keyswitch contacts. I've done this on my 2.5TL.
If Alt & CEL come on OK, the Main Fuel Relay is likely. Diagnosis should be to turn keyswitch to On, and listen for two soft clicks from under the dash and 2-secs of fuel pump running before cutting off. If only silence, you have a faulty main fuel relay, or less likely a faulty fuel pump. W/ a bad fuel pump you should still hear the two soft clicks of Main Fuel Relay from under the LH side of the dash.
good luck
good luck
$148-labor
$100- tow
$72 - parts
good luck
good luck
You replace the keyswitch assy which contains new switch contacts. Remove steering column cover, remove bolts (security bolts w/ punch) retaining ignition switch, and replace switch.
good luck
good luck
doncalvino (06-28-2015)
Zonian22
11-14-2015 01:20 PM
HydrasunGQ
09-14-2015 10:14 PM
Zonian22
09-02-2015 08:19 AM
