4 ne 1 with ground control springs
whoXwanXsum
4 ne 3.2 with ground control...
i have a 96 3.2 wher the hell can i find these? they arent listed on the site and a friend of mine with a shop cant find em either.
do you mean Ground Control Coilovers? if so, mine were ordered through a company called ProMotion..they are located somewhere in Cal.
i have a 2.5. i think your ride may use the same system.
BTW i think the cross ref is with the '96 Accord LX, EX.
hope this helps.............
oh snap!! hey turbo...you said you have ground control coilovers for your 2.5??? what year is your car? i also have a 2.5 and wanted gc coilovers SOOO BAD! how do you lower your car with gc? do you have those 2 medal half circle shaped tools to lower your height? how much did you pay for your gc's...without installation. and did you say the gc coilovers you got where the same as 96 accord lx/ex????? hook it up!
![EEK!](https://acurazine.com/forums/images/smilies/eek.gif)
Call up hocus Pocus they should be able to get you GC's.
The 90-97 Accord used the same springs as the 2.5 TL, well on the EIbach website the prokit part #s were the same for all them cars.
oh snap!! hey turbo...you said you have ground control coilovers for your 2.5??? what year is your car? i also have a 2.5 and wanted gc coilovers SOOO BAD! how do you lower your car with gc? do you have those 2 medal half circle shaped tools to lower your height? how much did you pay for your gc's...without installation. and did you say the gc coilovers you got where the same as 96 accord lx/ex????? hook it up................................................ .................................................. ...
i have a 96 2.5, its actually just one spanner (wrench) to lower or raise the height. there is a set screw that is located in the collet, the part that contacts the spring that must be loosened first, then re-tightened after ride height is attained. the cost was about $350. yeah same as 96 accord lx/ex
