Will 04 Tl rims fit 1st GEN RL
Want to know cause Im thinking about getting them and if they don't fit I'll just put on my 03 TL. Thanks for the input if you have any.
I got the 04 TL rims on my RL so they fit. Only thing is they are a little wide and becuase of that I'm looking to sell the 04s and get a set of 02 TL typeS rims. I can try and get around to taking some pics for ya. (cell phone pic )
Rampaging RL
all 5 lug honda wheels are 5X114.3mm lug pattern with various offsets, with the exception to the 2nd gen RL which is 5X120mm so im sure that the next generations of Acura/honda will follow this trend...
you can use ANY 5 lug from Nissans, Toyotas, Hondas, Acuras, even GM which are 5X4.5in (the same as the metric version)
i guess since we're on the topic, what tire size would look\ride best with 03 TL typeS wheels? the stock tire size on the TL is 215/50/17 and was going to go with that since that size is the cheapest i can find. also this is on a 98.
and i got an offer for the stock ugly rims and tires for $100. i just want those out of my life forever!
Rampaging RL
do either 225/45 or 225/40 17's those will be close to keeping the ratios the same for the speedo... also would look the best
if im not mistaken the TL type S wheels are 7"wide so 225s are best fit for that... you can go wider if you want but then the side walls start bowing out a bit...
sorta a look i go for personally but not too crazy... keep it clean
the TL type S wheels are 6 1/2 and i believe the CL typeS are 7". The cheapest tire I can find are 215/50/17. think that would look fine? I'm mainly looking for a as stock as possible look without ugly ass fan blade rims. but I'll look around for some 225/45 or 225/40
DiamondJoeQuimby
09-10-2015 11:40 AM
