AcuraZine - Acura Enthusiast Community (https://acurazine.com/forums/)
-   1G RL (1996-2004) (https://acurazine.com/forums/1g-rl-1996-2004-77/)
-   -   What are these called? (https://acurazine.com/forums/1g-rl-1996-2004-77/what-these-called-1011532/)
Ambam2020 Nov 4, 2025 10:36 PM
2001 Acura Rl ~180k miles.
my trunk is leaking and I think its at the bottom of the windshield. What is/are the rubber-metal-rubber parts called? is it one piece or multiple? Can I just clean it all and put a layer of silicone on it to reseal?
https://cimg9.ibsrv.net/gimg/acurazi...e07691ae5d.jpg
if you look closely, the rubber-metal-rubber at the bottom of the windshield is separated.
https://cimg0.ibsrv.net/gimg/acurazi...66d22a0dd9.jpg
this is in the middle of the windshield, the black line above the metal is supposed to be sealed against the metal.
kapikap Nov 6, 2025 06:44 PM
I would suggest you clean the area thoroughly, window cleaner and some rags are enough. Once the groove is clean,insert the seal in the groove. The corners can be sealed with silicone. The leak in the trunk could be because of the sunroof drainage line.
2000RL Nov 7, 2025 06:17 AM
Lower Molding - Acura (73251-SZ3-013) no longer available.
(https://www.yourwholesaleacuraparts....Y2LWdhcw%3D%3D)
Ambam2020 Nov 7, 2025 04:07 PM
thank you!!! At least I can look up more about it now. :) I'm pretty much expecting out of stock for anything for this car at this point...
© 2026 MH Sub I, LLC dba Internet Brands
