VSA ABS triangle lights on; need replacement mirror glass 00 Rl
guys, my vsa abs and the triangle w ! light is on. it is intermittent. sometimes it comes on sometimes it does not. is this vehicle speed sensor?
also I need a new/replacement driver side mirror glass(glass only)....where/how can I find this? I prefer to find a used OEM
i have the same problem, i took it to a mechanic did his diagnostic and came up with the rear speed sensor, so he replaced it but did not go away so he said that it the vsa abs pump in the front. been looking for one for a year now. but no need to worry it doesnt affect the way you drive you might just burn some rubber. but have it checked out by your mechanic might be something simple
60mph Soapbox Racer
I just got my 99 back from the mechanic, who replaced a front bearing and hub, and now my ABS light is always on and my TCS light comes on over 6mph. going to diagnose it this evening but I'd guess it's the speed sensor on the front left, where they put in the new hub. maybe they forgot to plug the sensor back in...
VSA light and wheel speed sensor
Does anyone have pictures or a pdf from a manual showing location and replacement instructions for front right wheel speed sensor and oil pressure switch for a 2000 Acural RL ?
Also I have seen and printed the pages online for replacing right rear window motor ….any suggestions for where to buy one …any special tools you need or recommend?
OR ….can you recommend a good manual either to download or buy hard copy?
Thanks,
Rogue
Thanks,
Rogue
mada51589
05-03-2022 08:54 PM
wusty23jd
09-24-2015 11:41 AM
Skirmich
09-15-2015 06:41 PM
