VSA and ABS Light
VSA and ABS Light
So I have a 2000 RL (~40,000 miles) that was my grandmothers which sat for about 7 years until now. It has come to the point where we would like to sell it, but there are a few issues that I have been working through.
I really don't know what to do from here. I get the same codes above when I try to use the service check connector or the diagnostic reader. What else could the main throttle sensor failure be if the tps is giving the correct output? Are there common grounds or wires people have had issues with in the past?
I really appreciate any advice. I've thrown too much time and money into this car already, hopefully this will work out in the end.
- The rear right window regulator was broken - fixed
- 9-3 drive buckle sensor failure - I replaced the buckle and now the light on the dash (to show if you are buckled or not) still works, but the code keeps coming back up
- 15-3 Faulty OPDS sensor - fixed. I replaced the module located in the front passenger seat back.
- 93-1 Main throttle sensor failure - see below
- 98-1 ECU unmatch failure - see below
jsch6584
11-12-2023 06:50 PM
Yui
1G TSX Problems & Fixes
09-21-2003 08:07 PM
