Tail lights stay on
Old 06-06-2017, 09:30 PM
budguy's Avatar
Tail lights stay on
I have a 1997 Acura RL and the tail lights will not go off when I stop the engine. The brake lights are on as well. Any suggestions?
Old 06-06-2017, 10:21 PM
Administrator
Ron A's Avatar
Received 1,006 Likes on 575 Posts
Welcome to the forums.
This thread has been moved from the Second Generation TL (1999-2003) Forum to the car specific forum applicable to your vehicle.
Old 06-07-2017, 06:16 AM
Received 16,265 Likes on 11,974 Posts
Brake light switch
I2canfix (11-08-2020)
Old 06-07-2017, 07:31 AM
Received 8,708 Likes on 6,715 Posts
definitely brake light switch.
Should be this I believe...
https://www.oemacuraparts.com/oem-pa...QtYXV0b21hdGlj
Or if the switch appears to be in okay condition but this pad broke: https://www.oemacuraparts.com/oem-pa...9tYXRpYw%3D%3D
It prevent the switch from being depressed as well.
Old 06-07-2017, 07:36 AM
^I would grab an autozone brake light switch for a few dollars instead of the OEM one for $36
Old 06-07-2017, 07:47 AM
for a car that old, I'd opt for that cheaper option as well..
justnspace (06-07-2017)
Old 06-07-2017, 06:48 PM
OLD_HATCH's Avatar
The rubber pad on the brake pedal has broken.
There are replacements at autoparts stores or you could also use a bolt/nut.
Old 02-13-2019, 11:49 AM
8auto's Avatar
when you say rubber grommet, do you mean the one touching the pedal? it sounds like that is the issue. get under the steering wheel and look up. you will see it. Brake or Clutch Pedal Stop Pad 46505-SA5-000 for Honda/Acura
SoL_TeK
02-04-2017 07:04 PM
N1h1l1ty
01-19-2017 11:19 PM
YVRCLR
10-04-2016 10:05 PM
0utl
07-18-2016 09:06 AM
rets
01-01-2013 09:50 PM
Quick Reply: Tail lights stay on
