Radio removal
Radio removal
Can anyone help me with taking out my H/U I want to connect a audiolink PD2 to the back of it also if any one has this in their car where did you mount it? BTW I have a 2000 non/navi.
Thanks in advance for any help
If this is what you're looking for ....
Pull up the trim around the shift knob first - it should just pry right out of place.
Then, pull up the console from where it meets the cupholder/trough.
Take out the bolts that are behind the ashtray
Pull off the upholstery on both the sides of the console - they look like little triangles and they pull right off.
There are two bolts on the left and one on the right that need to come out (from behind where the triangles were)
The brackets that the bolts went into need to be bent up out of the way so you can pull out the console.
This may not be the best description, but hopefully, it'll help....
Puma Jim
20
10-20-2016 11:59 AM
SinCityTLX
20
10-19-2015 11:23 AM
jdmaszfcuk
10-19-2015 12:31 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
