Pin diagram on ignition coils
Does anyone know the pin numbers on the ignition coils.
I need to bench test them.
Example: the coil would be lying flat with the boot to the left. Would number one pin on the left, two in the middle and number 3 on the right?
Any help would be appreciated.
With the ignition coil lying flat , the narrow end pointing to wards you and coil numbers showing on the left side at top of ignition coil, number 3 is at the very top ,followed by 2 and 1 is at the very bottom. The spec resistance for the primary winding between #'s 1 and 2 taken @ 77 degrees F should be 0.9 - 1.1 ohms. Note: resistance will vary with coil temperature.
I knew I could count on you guys!
Crazy Bimmer
03-09-2006 10:34 AM
