Keyless entry remote programming for 2000 RL
Could someone please post or email the instuctions for programming a keyless entry remote for a 2000 Acura RL 3.5? Thanks! thompsonbct@aol.com
Ultimate DIYer
Notes:
1) Entering the programming mode cancels all learned transmitter codes, so none of the previously programmed transmitters will work. You must reprogram all the transmitters once you’re in programming mode. The system accepts up to three transmitters.
2) To keep the system from exiting the programming mode, complete each step within 5 seconds of the previous step, and program the transmitters within 10 seconds of each other.
Steps:
1) Turn the ignition switch ON (ll)
2) Press the “LOCK” or “UNLOCK” button on one of the transmitters. (A non-programmed transmitter can be used for this step.)
3) Turn the ignition switch OFF (0).
4) Repeat steps 1, 2 and 3 two more times with the transmitter used in step 2.
5) Turn the ignition switch ON (ll).
6) Press the “LOCK” or “UNLOCK” button on the same transmitter. Check that the power door locks cycle to confirm that you are in the programming mode.
7) Press the “LOCK” or “UNLOCK” button on each transmitter. (You can program up to four transmitter per vehicle.) Check that the power door locks cycle after you push each transmitter button, confirming that the system has accepted the transmitter’s code.
97_RLer
Originally Posted by 97_RLer
Here you go! But read the entire procedure first before you start!
Notes:
Steps:
97_RLer
Notes:
Steps:
97_RLer
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
1997, 2000, acura, entry, key, keyless, manual, program, programing, programming, remote, remotes, rl, tl, transmitter
