HELP dash kit
Then you sir are in luck. You can fit a double din on the non-nav models.
It will simply bolt up to the metal brackets behind the wood dash, just like the oem radio.
The hard part of course is finding/making a trim panel to fit the gap that will be left when you install the aftermarket radio.
You'll also need a honda/Acura bose harness adapter.
Received 2,329 Likes
Same story with the navi model, just single DIN instead. Metal brackets are slightly off though, may require drilling.
yes you can.
it basicly bolts up like the oem radio to metal brackets behind the center coonsole.
Te har part is making/finding a trim piece to fill the gap that is left around the aftermarket radio.
check out a company called Beat Sonic USA. They are a tad pricey but if you want it to look good youll pay it. I Got mine from there. Im almost certain they make a kit for your year.
I wish I had the tools and talent to make a dash kit for mine, I'm gonna have to get a stereo shop to do it.
60mph Soapbox Racer
if you're certain you're not going to use the original radio what I did was remove the plastic faceplate from the radio, take off all the buttons and stuff from it, bondo over the holes, sand it flat, and paint it black. it fits/mounts perfect! i didn't cut a double-din sized hole in mine since i put a direct ipod line in to the amplifier rather than a new radio, but I imagine cutting a rectangular hole wouldn't be so hard to add to the process. you can even get OEM black paint at some auto stores.
9th Gear
Man o man!!! If u got time on your hands do the dash kit yourself! You'll feel good you did it and its a lot cheaper. I am in the process of putting my aftermarket deck in. When I geT to a computer I will post pics. My way was kinda hard I filed my oem dash into a big square. Drilled new holes in the metal brackets or brace that held the old one in. I am going to glue in a plastic plate to cover the empty space. Putty up the seams spray paint the whole center dash including the climate control area to make everything flow good and I'm done! A cheap diy job. Jus need some patience haha
Xtreme autosound (909-481-9555) installed a Kenwood DNX-7160 with all the features I wanted. See the link to their install. I love my setup after seen what people have done. http://i970.photobucket.com/albums/a...0/IMG_0956.jpg
emailnatec
29
09-28-2018 04:27 PM
