Fuel Pump Access Panel Location 98 RL
Hi all!
Need some help finding the access panel for the fuel pump on my 98 RL SE. I've changed the main, but still have high resistance on the pump. So I'm going to change it. The directions seem easy enough, yet I'm stuck on the second step:
1. Remove rear seat cushion.
2. Remove fuel pump access panel.
It sounds like it should be RIGHT THERE, but I cannot find it! Any suggestions on where I should look?
Thanks!
Thanks!
Okay, the access panel has been found and the pump changed! The directions didn't provide enough info to make this as obvious as it sounded. The access panel is actually located in the trunk just behind the seats, dead center. It helps a TON if you remove the rear seat bench and backs, but if you don't mind hanging out your trunk it can be done.
Hope this helps!
Hope this helps!
The following 2 users liked this post by jwbryan:
kid spartan (12-11-2012),
phins2rt (12-11-2012)
