Change transmission fluid on 02 RL with 100k
Whats the feeling regarding having the gearbox flushed on a 10 year old car with 100k on the ticker.
Some mechanics feel it can open a can of worms. Has anyone had problems with their RL after a fluid change?
don't do a power flush as that has been know to cause problems. It's easy to do a "drain and fill" by removing the drain plug, about 3+ qts will drain out, then refill carefully to proper level. This only removes about 1/3 of the total fluid so drive it several miles, going thru all gears to mix old and new fluid, then repeat the drain and fill. Use Honda/Acura trans fluid.
I bought my 98 RL with 148k miles, did 3 drain and fills and was amazed at how much it smoothed out the shifts. Now at 210k miles with no problems. I do a single drain and fill every other oil change (so at 10k miles).
Received 2,329 Likes
ALWAYS drain and fill. No power flushing.
3X drain and refills...... just want to make sure I understand this before attempting myself. The Owners Manual (pg. 238) says:
"....the technician should drain and refill it with Honda ATF-Z1 (Automatic Transmission Fluid), then drive the vehicle a short distance. Do this three times. Then drain and refill the transmission a final time."
I interpret this as a total of four drains and refills.... ?? Is the general consensus that three times is enough, or am I missing something?
Now at 210k miles and shifts perfectly.
mada51589
05-03-2022 08:54 PM
nanos
11-12-2015 08:41 PM
