Bulbs
Bulbs
I've read numerous threads on how to do LED conversions with the RL but I can't seem to find the bulb sizes for the door puddle lights and the cluster. Does anyone have an answer for this? thanks!
2004 Carbon Gray 3.5RL
http://www.superbrightleds.com/cat/l...-rl--/1-888--/
this should help...
as for the gauge cluster... that might be more work that you want to mess with. Been there, done that... if you remove all the screws out of the back of the cluster, make sure you put them back in the exact hole they came out of and to not over tighten them.
this should help...
The cluster has T 6.5 I believe. But listen to what Blackhatch says though I tried to do this mod last year and the only mod I ended up with was a non functioning speedometer and tachometer.
Yea, that^^. I did it and after I ended up with a dead odometer, but the LED was awesome. Well if you still want to tackle this problem, you need to take it slowly lol. I suggest you draw out the shape of where the screws are and tape it. Also, I think you need gloves to protect the circuit. I did not use gloves when I did it, probably that caused the odometer went bad?
ripit
09-26-2015 06:19 PM
