Brakes and More
Brakes and More
I was wondering if the brakes and rotors from a 2001 RL would bolt up on a 1998 RL. A friend of mine replaced his with drilled and slotted rotors he also added ceramic pads. I had installed the pads on my 1998 not realizing the difference until I heard a horrible grinding. Verified that his OEM rotors were way bigger and the pads slightly different. In the end I went to Autozone and purchased a new set of 1998 pads in the meanwhile. Has anyone else upgraded and if so with what. I really would like to use his hardware.
That's what she said!
I imagne that the components should bolt up just fine. I wouldnt put drilled and slotted rotor on your car though. Many of these "performance" rotors are cheaply made and will crack and warp much sooner than a premium OEM replacement from say NAPA.
GWEEDOspeedo
01-15-2016 10:39 PM
lanechanger
10-13-2015 10:56 AM
