AcuraZine - Acura Enthusiast Community (https://acurazine.com/forums/)
-   1G RL (1996-2004) (https://acurazine.com/forums/1g-rl-1996-2004-77/)
-   -   ATF cooler for 04 RL (https://acurazine.com/forums/1g-rl-1996-2004-77/atf-cooler-04-rl-1010487/)
MartinRLX Jun 14, 2025 05:31 PM
I would like to install aftermarket kit and connect into return hose from radiator to AT. So the question is which atf hose is returning from radiator?
https://cimg3.ibsrv.net/gimg/acurazi...17d1652fab.jpg
RxRC Jun 16, 2025 12:48 PM
That is a good question.
Do you think a cooler is necessary? Do you have any temperature info from the fluid? I think these transmissions are pretty solid.
thoiboi Jun 16, 2025 12:51 PM
If your place is to bypass the radiator altogether, why not just plug the lines and connect it in-line? why bother going through the radiator AND the ATF cooler?
MartinRLX Jun 16, 2025 03:48 PM
i think the best option is instaling cooler after radiator. I have Accord V6 and atv cooler is installed like that. I use my Acura in European Highways driving fast so i would like to avaif problems with gearbox.
RxRC Jun 16, 2025 03:58 PM
Right. And the rpm's are relatively high with only 4-speeds.
Acura00RL Jun 27, 2025 07:45 AM
My guess would be hose # 15 for the return from rad, right next to bottom rad hose connection to water pump inlet.
MartinRLX Jul 13, 2025 02:15 PM
you're right, hose 15 is return for atf from radiator.
ATF cooler is installed.
https://cimg3.ibsrv.net/gimg/acurazi...9805b1d5ab.jpg
https://cimg4.ibsrv.net/gimg/acurazi...b951216509.jpg
RxRC Jul 16, 2025 10:47 PM
Nice job.
thoiboi Jul 17, 2025 09:31 AM
How's the AT temps with the new cooler? Did you notice a substantial drop between stock and the new aftermarket cooler?
MartinRLX Jul 27, 2025 10:08 AM
my Acura is in parts now because i'm doing renovation so i can't test it. but I think i wont measure temp because it required new gauge.
https://cimg5.ibsrv.net/gimg/acurazi...35d944a6b8.jpg
© 2026 MH Sub I, LLC dba Internet Brands
