ABS & TCS Codes for 1999 RL
Old Dec 31, 2009 | 09:17 AM
Lefteye's Avatar
99 RL
Hi all,
Can anyone please tell me what these codes mean for my 1999 RL:
ABS
1-7
3-2
8-1
TCS
3-1
4-8
5-6
I did a search and the codes I found are for the 1996 & 1997 RL. Not sure if they are different from the 1999 RL.
Old Jan 6, 2010 | 02:10 PM
Lefteye's Avatar
99 RL
Anyone Please!!!
Originally Posted by Lefteye
Hi all,
ABS
1-7
3-2
8-1
TCS
3-1
4-8
5-6
Old Jan 6, 2010 | 03:32 PM
Ken1997TL's Avatar
ABS:
1-7 = Driver's side rear wheel sensor
3-2 = Solenoid Front to rear out
8-1 = Central Processing Unit (CPU) diagnosis, and ROM/RAM diagnosis
TCS:
3-1 = TCS Inhibition
4-8 = Driver's side rear wheel sensor
5-6 = TCS Control valve, Motor operation (2)
Old Jan 6, 2010 | 07:58 PM
OLD_HATCH's Avatar
damn. I wouldnt think all those components would fail at once. Did you purchase the car this way? It could be a wiring or ecm problem as well reporting false errors.
try resetting at all?
Old Jan 6, 2010 | 09:53 PM
Ken1997TL's Avatar
I'd check the driver's rear wheel speed sensor first replace it if necessary, pull the battery and hope the code clears from there.
Old Jan 7, 2010 | 10:38 AM
Lefteye's Avatar
99 RL
Thanks all for the reply. I have had the vehicle since June 2009 and no ABS and TCS lights until Dec. 2009. I used the procedures from this site to get the codes. I also tried the procedures from the manual to reset the ABS light, but that did not work. Will pulling the battery trick work?
Someone told me that if I want to reset the ABS, I should disconnect the battery from the car and touch both ends of the cable. I have not tried that trick because I don't want to damage any electronic components.
Old Jan 7, 2010 | 10:40 AM
Ken1997TL's Avatar
Just disconnect it for 10 minutes or so.
Make sure you have your radio/navigation anti-theft codes handy.
Old Feb 7, 2012 | 08:22 PM
Blakamalan's Avatar
i have da same problem wit ma car but wen i accelerate the tcs flashes n tha car dont pass 5 mph why might dat be
Old Feb 7, 2012 | 08:24 PM
Blakamalan's Avatar
tcs and abs problem
i bought da car wit the abs light n as time passed the tcs came on now yesterday the car wouldnt pass 5mph dus anyone kno why that is all the car dus is make the tcs flash on n off
Old Feb 8, 2012 | 02:16 PM
thaillest30's Avatar
Universal Soldier
Ummmm, Just a thought rephrase your question with a lil better grammar so others can fully understand you. No offense, I get the gist of what you are trying to say. Give more details on whats going on with your situation.
Old Feb 8, 2012 | 02:24 PM
OLD_HATCH's Avatar
I'm not going to be that kind. If you want people to help and understand please use proper English. Your not texting 12 year olds .
Old Jan 1, 2015 | 04:03 PM
trhester's Avatar
7th Gear
I know this is an old thread but, I have a 99 RL with a similar problem. The TCS light will appear after driving a little bit, but only when you make a turn. If you drive on a straight road, it may not come on at all. I took it to a Honda specialist and he hooked it up and said there were no trouble codes. Any insight or experience with a cure will be much appreciated.
Old Jan 1, 2015 | 04:06 PM
trhester's Avatar
7th Gear
P.S., if there is a way to retrieve codes without a special device, please let me know.
Old Jan 1, 2015 | 06:30 PM
Ken1997TL's Avatar
Sounds like a bad vehicle speed sensor or turn/yaw sensor.
Old Jan 2, 2015 | 02:47 PM
trhester's Avatar
7th Gear
Is there a method to display trouble codes without a computer?
Old Oct 16, 2024 | 01:15 PM
2000RL's Avatar
Veteran: Navy
Is this an option?
Amazon Amazon
Jamus22
Jun 11, 2023 10:08 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
