99 Acura RL has an oil leak. I need help!
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
I purchased my 1999 Acura RL the beginning of the year and now i see that it has an oil leak. The splash shield of the bottom of the oil pan are always cover in fresh oil but I can't seem to find the source. I have several pictures i've taken of the oil pan if anybody sees something that doesn't look right could you point it out I do work on my own car so I want to fix the problem asap. there is a small opening by the oil pan but I do not know if that belongs there or if that is where the oil is leaking. Thanks
![](http://i1346.photobucket.com/albums/p689/chatosanchez89/IMG_20130724_193057_zpsa2bbcb44.jpg)
![](http://i1346.photobucket.com/albums/p689/chatosanchez89/IMG_20130724_193024_zpsd1627bc4.jpg)
![](http://i1346.photobucket.com/albums/p689/chatosanchez89/IMG_20130724_193000_zps64634ffd.jpg)
2004 Carbon Gray 3.5RL
Looks like a normal problem on RLs.
Looks like a leaky rear main seal. I've never had to replace one before on either of my RLs, but i know it's a job for you if you know what you are doing or a job for someone at a shop who can hook you up with a good deal... otherwise, top it off and keep going.
That is what I've always been told. It's not enough of a leak to worry too much, but if you're like me, you hate seeing that. I'll see what i can find about it to do it yourself.
Zonian22
11-14-2015 01:20 PM
IIDXholic
10-08-2015 07:53 AM
asahrts
09-04-2015 05:55 PM
