20x8.5 +30 rim on 2002 acura Rl
I'm thinking about buying some rims that are 20x8.5 with a +30 offset. I am unsure if these wheels will fit on my car and I am not sure what size tire I should get. I'm looking to have the most side wall for the tire without rubbing on the fender. I have all stock everything and I am fine with a little poke from the wheels as I know how to drive without hitting curbs. Thanks for any help. :)
The link below will allow you to put your current tire/wheel information in and the tire/wheel size you want to use and will display the difference between the two. It will also give wheel well, fender. and suspension clearance information.
Custom wheels, rim tire packages |
