2002 rl no turn signals
I have checked all the bulbs, installed a new relay, & checked the one under the hood fuse was good Is there a 2nd fuse I am missing Can my problem be in the hazard switch on the dash or the turn signal lever/switch I can push up or down on the lever & hear the relay click but nothing else One last little thing about my problem when I first push down on the turn signal lever is seems for just a split second the signal might work then just a click in the relay let it sit for a minute & try again the same thing acts like it wants to work trips out I appreciate any help with this problem
Welcome to the forums.
The following is posted at the top of the New Member Introductions Forum: Welcome! Please introduce yourselves here, BUT ASK FOR HELP IN THE TECHNICAL FORUMS
Since this is a topic/technical issue which will require replies and discussion, this thread has been moved from the New Member Introductions Forum to the model specific forum for better response.
