2000 RL Running Ruff Coil Pack?
Old 08-01-2013, 05:02 PM
6th Gear
jtaylor's Avatar
This is my first time to post. I have a 2000 RL 3.5 that just started running very ruff. While it is running I can see and hear the spark just above the cylinder next to the firewall on left side (facing the front of car). Not sure what cylinder number that is. Is that likely the coil pack? Wiring issue? Is the pack difficult to change?
Thanks in advance
Old 08-02-2013, 12:59 AM
3.5RLv-tec?'s Avatar
I have no idea what are you trying to say. How can you see the spark plug while driving ( unless you mean spark from the engine then it is really dangerous!) Anyway, are you trying to tell us that your car is running rough and you think the spark plug or the ignition coil might be the trouble? Well, I can tell you from my experience, when I had a misfire in one of the cylinders. It was a crack ignition coil and I replaced it with a new one. The misfire was gone and it is running smooth now. You might want to check all the spark plugs for oil and check for crack on the ignition coils. Hope that's help.
Old 09-04-2013, 11:53 AM
Babafats's Avatar
Check ur map sensor
08-15-2019 12:58 PM
The Machine
09-24-2018 08:27 PM
1fatcrxnem1
22
06-01-2018 01:23 AM
PortlandRL
09-14-2015 12:01 PM
Mike Bertram
09-10-2015 09:27 AM
Quick Reply: 2000 RL Running Ruff Coil Pack?
