120,00 mile check up gone bad?
i recently brought my car in for a 127,000 mile check up and they said:
i needed a very important 120,000 mile check up ($575)
also they told me that i needed my timing belt looked at, didni't mention as to whether it needed to be replaced and estimated that at ($760)
also a $180 fuel system clean
Grand Total : $1515
anyone know anything about this, similar situations or can help me out as to whether i need this or am getting ripped off with all of this.
thanks.
(the car is a 96 RL 3.5 Heather Mist/ Tan ~129,000 mi)
Grand Total : $1515
thanks.
registered pw
i would ask what the 575 check up is for, you may be able to do most yourself.
now every 25k i would have the trans fluid changed,
100k the timing belt, unless those earlier years required it at 60k
the coolant you can do by yourself prob for like $15
you may want to replace the brake fluid, should be less than $20 with all supplies.
most of the stuff they ar going to do is prob just checking.
i don't know much about the fuel system cleaning but if you changed the fuel filter for less than $15 and its easy to replace, if you did it like every 25k also maybe sooner
the only thing i would really have them do is the timing belt,water pump if its due
mada51589
05-03-2022 08:54 PM
jamestheunderdog
07-19-2016 07:58 PM
