whining sound during idling and also when turning steering wheel
Old 10-18-2017, 02:56 PM
mav888's Avatar
My 2007 RDX started having the whining sound during idling and also when I turn the steering wheel. Acura checked it and indicated that the power steering pump and reservioir unit needs replacement and also the drive belt. Quoted me $1200. Said no thanks and went to a local mechanic and got it done for $500.00.
Old 10-19-2017, 12:08 PM
Tomtwtwtw's Avatar
I would have started with simply replacing the p/s fluid. Mine started doing this out of the blue at just over 100k miles. Changed fluid (easy DIY job), has been perfect ever since (126k now).
Old 10-19-2017, 12:31 PM
Received 8,582 Likes on 6,629 Posts
awesome
Old 10-19-2017, 01:06 PM
mav888's Avatar
Yup considered that. But my local mechanic indicated that power steering pump unit was leaking fluid and the drive belt does need to be replaced, worn out.
Old 10-20-2017, 11:21 AM
Tomtwtwtw's Avatar
Shitty...at least it was only leaking at the pump, and you got a good deal at a local guy. The CR-V from the same period tends to leak from the rack itself, which is well over a grand to replace.
