Vs a code 25
Any ideas what this code is? Came on today, resets with the ignition cycle but comes back after driving less than 1/2 mile or so.
Originally Posted by dave119
(Post 16309458)
any ideas what this code is? Came on today, resets with the ignition cycle but comes back after driving less than 1/2 mile or so.
Those codes usually involve brake sensors, speed senors, yaw sensors, etc. Stuff that involves your VSA (vehicle stability assist) system. Have you recently had brake work done, or been towed, or anything to do around your wheel areas where a sensor could have been damaged? I want to say VSA 25 specifically refers to a yaw sensor, but the codes are not standard so an independent Honda shop may be the best place to start.
Originally Posted by Tomtwtwtw
(Post 16309555)
If I remember that’s your yaw senser, I had that aame issue. The dealership just replaced that sensor and I was good to go. The other one might be your brake pressure switch I had to replace that too. |
