small puff of white smoke
Old May 25, 2011 | 08:05 PM
rpkrdx's Avatar
i noticed today when i start up a small puff of white smoke comes out the exhaust. it was only sitting for about a hour after driving for about 20 minutes. any ideas ?
Old May 26, 2011 | 12:58 PM
bluecarbonfiber's Avatar
WTF?
carbon build up
Old Jul 12, 2011 | 03:36 PM
B20SOL's Avatar
6th Gear
does it go away after it's warmed up? Have seen a few 07 and 08's starting to leak oil out of the turbo (seals)
Old Apr 26, 2012 | 08:59 PM
vaprea's Avatar
White smoke typically is carbon / Coolant
Bluish smoke = OIL
Old May 2, 2012 | 04:54 PM
InfamousJamous's Avatar
PM me if you need a reply
Check your coolant level. If it looks abnormal then have a combustion leak test done.
I had a cracked turbo housing that leaked coolant. Burning coolant produces white smoke.
Old Jun 1, 2012 | 10:28 PM
02SLVRSXS's Avatar
5th Gear
You are either burning coolant or oil.
Both can and will make white smoke. You can usually determine which it is based on the smell of the smoke.
Most likely from the turbo, but could also be bad rings as well.
Old Jun 1, 2012 | 10:33 PM
Old Jun 3, 2012 | 06:12 PM
DRR98's Avatar
Wow that was dead for a year. Dance zombie.
Old Jul 26, 2012 | 07:49 PM
rpkrdx's Avatar
Acura wanted to do a oil consumption test never said anything about coolant or doing compression test. So traded it in 7/12/11 and someone in another town purchased it from the Acura dealer I have seen it driving around but never talked to the new owner about it maybe a member here ? O well my Acura days are over like the turbo engine loving my g37xs
hashbrown
Feb 18, 2022 11:20 AM
tsx_boy
Dec 13, 2019 08:33 PM
Jimmy_D
Oct 7, 2015 11:52 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
ceb
ILX
Sep 27, 2015 10:56 AM
