Second Maintenance Minder Service
Well today my oil life percentage dropped below 20% and I got the maintenance minder warning for my second service. Not bad for 11 months and 12K miles of ownership! I was surprised though - I got a B16. The 6 apparently means that the fluid in my rear differential should be changed. Is this normal? What have others been seeing for their second service requirements? I didn't expect that one...
I'll report the costs back after my appointment on Wed...
Mike
Mike
Mike
Mike
Catnipppants, my maintenance minder triggered only a B1 , no 6 involved, for my second check. This was after 11,000 miles and just under 9 months.
I think I'll be hit with the 6 check for my third, expected to be at 16,500 miles this coming October, maybe?
There's a note in the manual about needing to change it more often if you drive in mountainous areas. Could be that it knows that VT is pretty hilly.... who knows. I will be curious to see how much they want for it given that the change process doesn't seem to be documented in the manual. I'm assuming that this means that Acura wants the dealer to do it. I'm going to be pissed if it's expensive and I'm forced to go to my dealer for maintenance every 12K miles....
Mike
Mike
Originally Posted by XLR8R
Piazza Acura of Reading, PA lists a price of $90.95 for Rear Diff (6) service. along with $99.95 for the B service and $34.95 for the 1 service
Mike
That's more in line with what I'm expecting....~$250. I just can't seem to get any work beyond an oil change done for less than $200.
Mike
Mike
Most of a B service is inspectiion anyway; looking for leaks and damage. I just did my B1 for $42; the cost of Mobil 1 and the filter.
The actual cost of ATF for the SH rear diff is about $20. If you have the inclination and a place to jack the car, DIY is the way to go.
The great thing is -- Hondas are designed for simple, easy, routine maintenance with basic tools -- it's my favorite car to work on.
Wow, $228. Then $225.85 from Piazza means there's little difference, at least in these two dealers.
p.s. I wear those wimp-ass yellow dish-washing gloves
oh...and I have a real problem around here getting rid of used oil.
Mike
Mike
Mike
Boy, how times have changed...
Originally Posted by Tripp11
Hell, it seems just like yesterday when me and my pops were changing the oil in his old Chevy pick-up, and we would then dump the oil along the fence lining the field behind our property - the farmer said it would help him keep down the weeds and such growing along that stretch of the fence.
Originally Posted by mav238
yes, indeed... but are you going to keep dumping the used oil there??? eventually, it will get saturated and affect the area around it, or birds or other animals get toxicated by it.
Times have changed, for sure.
08_UA7_Gr33k
02-11-2016 02:17 PM
