Parasitic draw.
Parasitic draw.
So… my 2010 RDX with just over 209,000km on it was at my local Honda dealer last week getting a valve adjustment, valve cover gasket etc. done and I also asked for a charging system check as it dies or has a hard time starting after sitting for a few days.
they confirmed I have a parasitic draw of 0.145A. I declined to get it further diagnosed because they were asking for another day and $400.
I got a multimeter and the alternator and battery were all good and I measured a drain of 0.76-0.24A, way more than they told me I had.
I went and started pulling fuses one by one. I pulled fuse 32 in the secondary engine comp fuse box and that dropped the draw down to ~0.02A (The recline function for the front passenger seat lol). I then drove for over half an hour to run errands and got home and remeasured. To my surprise I still had a draw of 0.25A. So I repulsed some fuses and fuse 10 in the engine main fuse box very clearly caused a draw of 0.23A as appeared and disappeared the second I pulled the fuse or put it back. So after some research, knowing the Bluetooth/hfl module is commonly an issue, I put the fuse back and went to unplug the Bluetooth module. And bam the draw went down just as it did when I pulled the fuse.
I also put fuse 32 back to double check that it was still a problem and it was.
so for now I’m gonna live without Bluetooth or a reclining passenger seat to see if the car starts better each morning and after sitting more than a week.
just incase anyone else has issues like this, here’s my experience!
JarretF (08-06-2023)
im wondering if replacing it is an option? Not sure if these things are car specific and need reprogramming. I’m not too worried about it as I can just use the usb dock to play music and I never take calls while driving anyways hah
i just saw a YouTube video of someone with an 08 and they had the exact same amount of parasitic draw measured and went away by unplugging the module!
