Need help installing tps
Photographer
Originally Posted by MikeRDXNJ
You probably want to go to the dealer to get this done
you dont have to go back to the dealer to have this done. the place where you had your aftermarket rims installed can do this for you provided they know how to install a TPS correctly. just make sure they know what they are doing because to replace a TPS is quite costly. one question though, do you even have your TPS?
It's gonna be pretty costly because your tires are already mounted on your rims. The sensors themselves aren't too expensive to buy, like <$25 each. Not sure how much they will charge you to dismount the tires from the rims, install the sensors, remount the tires and rebalance. This all should have been done before you mounted the tires. Hopefully you have the equipment available to you to do it yourself.
cycdaniel
12-17-2019 10:58 AM
pistacio
09-26-2015 09:45 AM
