Need help “P0976” 😞😞
Hello everyone ✋🏽
I have a 2007 rdx tech and is throwing transmission code p0976 short circuit Solenoid b....
but very strange because I replaced all the solenoids and still having issues, however I did notice that if leave it neutral and I clear the code and turn it back on I’ll put in drive n it drives fine no code until I come to a stop or a climb.
i also noticed that if I just turn the key on the while is park after clearing the code while the car is off I can hear something clicking in the engine bay n the code comes back immediately while the car is off????
anyone with a similar situation please help
it does have a new battery,range sensor,shift cable, n all solenoids
Hey buddy, sorry no one has responded to you on this. I need to get the obvious question out of the way up front: are you good with a multimeter and electrical diagnostics? If you're not comfortable with these, get the car to your trusted repair facility. If you are comfortable, I can try and help you through this issue as, if you've already replaced the solenoids, this is 100% a wiring issue and it needs to be traced and repaired.
-Shane
-Shane
