NAV Problem??
NAV Problem??
After setting a destination and has completed the route and when I go to view "previous destination" there is nothing in there... Is anyone experience this or is there is setting I need to do? Thanks
If you are entering a new destination that isn't in the address book or home, it should appear in the previous destination list.
fix
Hey all,
I had this problem after I replaced the battery in my Acura TL, for some reason my Navi would never remember my Previous Destinations. On another message board someone suggested that it had something to do with Navi memory getting bogged down.
Here is what I did to fix the problem:
Hold down the "MAP/GUIDE", "MENU", and "CANCEL" buttons about 3-5 seconds while the Navi is on.
You should see the Technical Setup Menu.
Click “Unit Check”
Click “Navi ECU”
Wait until the system is done “Detecting...” and shows a Green “OK” and then click the “Mem Clr” button. (Note: this will basically reset your entire Navi system, all system preferences and address will be erased.)
After I did that my “Previous Destinations” memory returned.
Hope this helped!
Click “Unit Check”
Click “Navi ECU”
Hope this helped!
SidhuSaaB
05-30-2020 12:40 AM
navtool.com
31
11-16-2015 08:30 PM
