how can i find fault code in acura rdx 2009?
Old 01-05-2018, 08:35 AM
amodir's Avatar
How can I get the fault code for checking break system warning message in acura rdx (2009)? Or in general how can I get any fault code for my acura rdx 2009?
Old 01-05-2018, 08:51 AM
Received 16,266 Likes on 11,974 Posts
if it is a Check Engine Light, or CEL, you can go to autozone and have them hook up an OBDII reader to the car and check the codes. it's free unless you live in cali.
I'm not too sure about your warning tho. your warning says "CHECK BRAKE SYSTEM!"
which could indicate a multitude of issues that you would have to inspect or check to see...
it could be low fluid because of the cold making liquid shrink.
it could be an ABS sensor broken or disconnected
it could be TPMS acting up
drakescherer
1G RDX DIY & FAQ
05-09-2022 04:29 PM
SoL_TeK
02-04-2017 07:04 PM
EE4Life
10-26-2016 10:10 PM
deadlyCL-S
04-29-2001 08:40 PM
Quick Reply: how can i find fault code in acura rdx 2009?
