dashboard flaw
dashboard flaw
I have a tech 07 RDX ebony interior. When it is sunny outside and I look at the dashboard on the passenger side I see an outline which looks like it is where top part of the dash is attached to another part. It is an outline of something. Is this a flaw or a part of the airbag system? I did my best at explaining it. I guess perhaps I should look at some cars at the dealer and see if I can notice it on theirs. Does anyone else have this issue?
For my RDX, I'm starting the 303 application immediately and will do so every month or so in hopes to prevent the dash fade and airbag outline.
If it is a airbag outline, is this something that Acura is aware of? Can they not engineer something to get rid of the outline? It almost looks like something heavy has pressed on the dash which is making something underneath put pressure on the dashboard from below. If others do not notice this on theirs perhaps I need to see what my warranty will do for me. My car was manufactured in April of 07 and I have had it less than a month.
Tripp11 thanks for the tip. I will check it out to keep things looking good.
![what](https://acurazine.com/forums/images/smilies/what.gif)
Mine was manufactured May '07. Anyone else see the "crease" on the passenger's side of the dash?
I talked to the service department as I didn't notice this as much on the demo cars at the dealer. The service department manager stated it was because Armor All is shining it making it more noticable. He said that the material is thin in that location for the airbag. I would think that Acura could have done something different for this. I would guess the dash will get worse with time. I am disappointed with this look for what I paid.
He said the dash was just thinner there. I can't believe we are the only ones noticing this.
I wonder about the 08's. Perhaps Armor All low shine or natural finish would make it less noticable. I personally like the shiny look. How does the 303 compare to Armor Al products?
I stared at my dash my entire drive from work today, and I couldn't see any lines on the passenger side of the dash. I haven't used any armor all or 303 or any protectant on it. just use a damp cloth to clean the dust.
I'll stop using the protectant, but I just want to make sure this isn't a weight/pressure thing. Should we be sensitive to what we put on there...or how hard to scrub when cleaning then?
Originally Posted by Boon
Thanks Sasair. I've been PMing others and a few have noticed the crease too (others haven't).
I saw the outline prior to using 303 protectant, and after using I still see the outline at the right angles. The main reason I chose 303 is that it offers UV protection and will hopefully minimize dash fade which my TL exhibited only after 6 months with no protection. Plus, I think the 303 has a lower shine than any Armor All product I've ever used.
Start with your dealer service department and follow-up w/ a phone call to the 800 Acura Customer Service line. Start the documentation trend now regarding your perceived issues with the dash.
Do I think you'll get anywhere? No because I think every dash I've looked at looks the same - and it doesn't bother me much. However, if it bothers you, make the calls.
That's all you can do.
