dash rattle cooler temperatures RDX
Old 10-17-2007, 01:32 PM
shm
3rd Gear
shm's Avatar
Dealer found source of what sounded like a fast tinny rattle in dash of my RDX.
The problem was a brace under the cowl cover between drivers fender and cowl. A bolt was mis-threaded and about 70 degrees it went away! A hard one to find, credit to Acura of Boardman, OH.
Old 11-09-2007, 10:34 PM
4th Gear
DJ 75's Avatar
shm - I wonder if your noise is similar to mine? I have a tapping/snapping sound near the top centre dash that can really get fast/persistent. The dealer has had the centre grill off and added padding a couple of times, but it's still there. Could you describe your rattle in more detail?
Old 11-12-2007, 10:10 AM
shm
3rd Gear
shm's Avatar
dah rattle
Hello DJ75
The rattle sounded like loose metal vibrating, which it was! I believe there was
another tread posted about a loose fitting sun sensor which is in the center of
the dash, you may want to check that for tightness.
SHM
Old 10-05-2018, 05:09 PM
pandaman's Avatar
I know it's been awhile. Do you have a picture of where the bolt is?
Old 10-05-2018, 05:10 PM
pandaman's Avatar
Have you found the bolt that got loosen?
Old 10-05-2018, 06:42 PM
Tomtwtwtw's Avatar
A while? We're talking 11 years! I think this is the oldest thread revival I've ever seen. I highly doubt either of these guys are still active on the forms with the 7 total posts between them. Hopefully someone else will see this and chime in though.
Old 10-07-2018, 12:38 PM
CSmoney28
CSmoney28's Avatar
It sounds like in the drivers side hood where the intercooler bolts were on the ram intake for the top mount.
Mike Pilipenko
03-26-2024 09:21 PM
spoiler900
10-10-2015 06:48 PM
flybyglass
09-24-2015 01:12 PM
2Quik
09-23-2015 01:03 PM
eastcoastguy
09-23-2015 06:29 AM
Quick Reply: dash rattle cooler temperatures RDX
