Check Engine Light - Code P1717
Went to back the car out this morning and noticed the Check Engine Light came on. The D started blinking on the dash. Turned the car off and turned it back on and the D no longer blinked. The CEL stayed on.
She shifted and ran fine with no issues. I then took her to Pep Boys to pull the code and clear it. Here's the code: P1717 Manufacturer Control Transmission No issues since then and the CEL did not come on again. :wish: I Googled the code and didn't find anything useful so I thought I'd post this in case anybody else tries running a search. From what I've read, it could have been caused by an issue with the shift lever. I also read that it's an electronic issue, not a mechanical issue. I'm assuming that it's because the shift lever was between gears when I was reversing/forwarding to maneuver out the driveway. I'll follow up if anything. She does have 141k miles, and yes my gas cap is on tight ;) |
Sorry, should have posted in Problems & Fixes.
141K wow...but one thing have you done a transmission fluid change at sometime ?
Yeah, I flushed it when I bought her at 133k.
Thanks for moving the thread btw. |
| All times are GMT -5. The time now is 05:48 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
