Battery terminal corrosion - bad ground?
Old Jan 7, 2025 | 01:46 PM
EasyLoveRDX's Avatar
Question Battery terminal corrosion - bad ground?
Grettings fellow AZers...
My buddy mentioned that he thinks I have a bad ground somewhere. He thinks this because I had cleaned my battery terminals about 4k miles ago, but there's already a little new corrosion forming around the positive terminal. I even put those anti-corrosion washers around both terminals.
Has anyone ever dealt with this before?
Old Jan 7, 2025 | 02:01 PM
i'm not sure how he conflated those two things.. I clean the terminals every time I pop the hood and I also spray on some battery terminal protector
Amazon Amazon
If you had a bad ground, you'd also be experiencing some other electrical issues but the corrosion is not a symptom of that but in fact a cause for it as well.
Old Jan 7, 2025 | 02:38 PM
That battery terminal spray is the .
Old Jan 7, 2025 | 03:10 PM
Tomtwtwtw's Avatar
There are a number of things that can cause terminal corrosion, some outside your control. Over/undercharging, age of the battery, loose connections, high humidity/temperature, etc. I had to replace my positive battery cable on my first gen shortly after I bought it due to excessive corrosion that I didn't catch in time. After that I just brushed it clean after every oil change, and *really* cleaned them with a cleaning solution every time the battery itself needed to be replaced.
Old Jan 7, 2025 | 06:30 PM
John from PA's Avatar
You can get that spray terminal protector for less $$$ at Advance (and probably Autozone). It is also new formulation with an “acid indicator”. The liquid changes color should an acid leak be detected. That of course could be the root of the OP’s issue.
Old Jan 7, 2025 | 08:34 PM
Perhaps, though the Battery Terminal Protector has more 'chemical' solvent bang for the extra buck.
Battery Cleaner with Acid Inhibitor:
Old Jan 8, 2025 | 05:57 AM
mrgold35's Avatar
mrgold35
I live in the always hot southwest and battery terminal corrosion for me is usually from:
- battery over heating (sometimes overcharging too much with a battery charger can have the same corrosion effect)
- leaking battery fluid (sometimes because of an extra hot engine bay)
- battery age
We don't use a lot salt in winter (volcanic cinder with everyone with windshield cracks). Rain/snow yearly range is 6-8 inches per years (snow in morning and gone by next day 90% of the time). I ended up switching to AGM batteries when available when it is time to replace for my vehicles to reduce the temperature swings and battery fluid corrosion issues.
Old Jan 9, 2025 | 02:45 PM
Thanks for all the replies.
Firstly, I live in New England where they put wayyyyy too much salt on the roads. I do my best to wash my car once a week during this season. We also have significant temperature & humidity fluctuations (my house has both AC and two different furnaces because of how hot and cold it gets).
Currently my battery is about 3 years old. I usually get a new one at AZ or OReillly ever 3-4 years. Current batt is a diehard silver which I think is Oreilly's house brand.
I have the battery terminal cleaner with acid indicator - recently started using it for my batt terminal cleanings. If the other stuff really works better, I agree it's worth the $8 investment.
I guess if it's normal I won't worry about it, but I'm trying to keep up with preventative maintenance so the car lasts as long as possible. I'm all ears to any suggestions beyond just cleaning the terminals when I change my oil.
This on my to-do list for my lady's 2019 HRV - she had been bringing her car to the dealership for service until recently and they never made her replace the battery. When I finally replaced her battery, it took a half hour just to clean off all the corrosion and get the positive terminal unhooked. It was that bad.
Old Jan 10, 2025 | 06:49 PM
Interesting point by @zeta. My bad, these are two different products, one is a Battery Terminal Protector and one is the Battery Terminal Cleaner.
Old Jan 10, 2025 | 07:36 PM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
Years ago we used to glue pennies to the battery - https://www.cartalk.com/content/art-dreaming-or-were-copper-pennies-once-used-save-batteries
I
t's possible you have a crack in your battery casing somewhere. You might need a sacrificial anode.
Chiller2002TL
Sep 25, 2018 02:46 PM
ShagJagJim
Jul 7, 2014 10:51 AM
MSG C5
Aug 7, 2013 09:34 PM
mcnally215
Sep 28, 2009 11:40 PM
mlb585
Dec 6, 2005 06:42 PM
