A3 service minder, followed by B13?
A few months ago I had service A3, oil change and transmission fluid flush.
Now the minder says B13, so oil/filter, and also transmission flush again?? In just 4 months??
RDX 2007, base, 95K. Shifts great.
When, oh when, will people learn to provide enough data for a response? Who did the service, and who reset the MID, on the initial A3? Has a *3* ever been shown on the MID, previous? Have you always owned the vehicle from new? or purchase used? We can't see your vehicle, can't read your mind.
mrgold35
I get my RDX serviced at the Acura dealership and I have to double-check to make sure they do everything. I would check your last service receipt to make sure they did a full "A3" service or "A" service and forgot about the 5AT and/or transfer fluid changes. I'm not sure if the M.I.D. is smart enough to know if fluids where changed or not after the M.I.D. is reset at the last service?
A: Replace Engine Oil
B: Replace engine oil and oil filter. Inspect various systems and components.
1: Rotate tires and check tire pressure and condition
2: Replace air cleaner element, check drive belt, and replace dust and pollen filter
3: Replace transmission fluid and transfer fluid (if equipped).
4: Replace spark plugs, replace timing belt (if equipped), inspect water pump, and inspect valve clearance.
5: Replace engine coolant.
6: Replace rear differential fluid (if equipped).
And to the OPer, sorry, my thought process did not completely make it into my previous reply - the dealer has the ability to individually reset the various notifications on the MID, and may have not reset the "3" service the first time (A3), so it was "still-there" at the next MID report (B13). When you yourself reset the MID, all notifications are reset. The dealer resets them (usually) individually.
And as MRGOLD has said - you can/ should check yourself, after the service, to see if the MID has been reset correctly, by looking at the MID yourself. See your OM for how-to.
mrgold35 (05-16-2014)
mrgold35
According to the manual it is easy to reset the MID in my base RDX. Press and hold the reset knob for 10 sec. I didn't know the dealer could reset each service item separately. That explains it. They probably forgot the "3".
In any case, last visit they charged me $150 for the ATF flush. I have to take this at face value, so it was done already.
Bottom line is, next ATF flush is at 180K, other things equal.
The tranny flush may actually pop up every 30k or so going forward. I believe each flush changes out about 1/3 of the fluid, so after the first it becomes a fairly regular maintenance. However if you want to save money look for a shop the specializes in Honda / Acuras. The one I go to only charges about 60 bucks for the flush.
There is a documented procedure that calls for flushing it 3 times with some driving in between to mix the fluids, but I don't see the dealer doing that for 150. (based on the parts and labor required I'd think a dealer would charge at least 300). I think it's 9 quarts (@ ~10 bucks per) plus a good 90 minutes of labor if you do the full deal.
The dealer uses the special Honda *device* which interfaces with the ODBII port, to read DTCs and also to reset any MID notifications. I do not know really how that device reads or resets MID notifications. But I would guess that if the MID has not actually reported a notification, then the dealer cannot reset such notification, since there is no actual notification. Or in other words, the dealer cannot reset the start of a new service period for that item - but I do not know that for a fact.
So performing any service early, such as an ATF change, means that you must then keep track of when to do it again (determine the next service interval).
However, do keep in mind, that a MID notification can be seen, before the MID displays 15% oil life and automatically *notifies* the driver that a service is due, when the engine is first started.
That is, you can use the driver procedure that would normally be used to actually manually reset the MID, to just view any current notifications and the current oil life, without actually performing a reset (CANCEL). In other words, any notification, such as ATF (3), may (or may not) be displayed by the MID, *before* the oil life reaches 15%.
I hope that the above is clear, but it is the best I can do with the "written word".
Lets keep in mind that I only drove 4K miles since the last ATF flush per the A3 MID.
About costs: I have the current service coupon for "3" " replace transmission fluid" from the S Monica Acura dealer at $130.
Follow-up: I went to the dealer and they said, only do the B1 service, ATF is fine, and they reset the "3" symbol.
It is useful to have all work at the dealer, they have all the info in their system. So there is no confusion as to what needs get done.
It is useful to have all work at the dealer, they have all the info in their system here. So there is no confusion as to what needs get done.
