07 RDX Steering noise
Hello everyone, got the RDX a few months back for the wife, she was telling about a weird noise in the steering, however it went away before I could hear it. well last night it was a about 53 degrees and the noise happened. Weird thing is the noise went away as fast as it appeared. PS fluid if full. I am thinking O ring from my research here. I am thinking I am going to have to do a drain and flush of the system as I don't know when or if the PS was ever serviced.
should I go to the stealership? or is this something any mechanic can do? Thanks in advance for your help.
Video is below
Video is below
You can use the Turkey Baster method to replace the PS fluid yourself, over a couple of days, or even in one day. Takes about 15 minutes to drain the PS tank once, and you do that about 6 times to replace around 70-80% of the old fluid.
Here is a thread, scroll down or use the table of contents at the beginning of the first post:
REPLACE THE POWER STEERING FLUID USING THE TURKEY BASTER METHOD:
FLUSH THE POWER STEERING FLUID:
https://acurazine.com/forums/showthread.php?t=828859
That thread also describes a method to fully flush the old fluid, but requires removing the right front wheel and wheel well inside plastic splash shield. But that is still easier than another thread which describes a flush which requires removing the front bumper.
Your problem of course, is that by the time there is noise, it is likely that either the pump or the steering rack has been damaged. The rubber seals wear from the slurry of metal particles and PS fluid. Over a period of time, the aluminum parts of the steering rack also wear.
There is a thread in the TL section which describes replacing the seals in the pump, for like <$10. A new OEM pump is several hundred dollars.
Try searching this forum for more info.
Wow, heard some odd noises in this clip, turned out to be some kids down the hall.
take it to the stealership.
DEFINITELY the o-ring!
Found this thread last night:
https://acurazine.com/forums/3g-tl-problems-fixes-114/diy-105-power-steering-whine-fix-754586/
Bought the o-ring today from my local Acura dealership for $.75. It took less than 5 minutes to remove the 10mm bolt and swap out the crappy black o-ring for the new orange one.
Don't unnecessarily give you $ to the stealership! 10mm open box wrench (stubby one if you got it) will get the job done. I changed mine at lunch in the parking lot at work.
GL
GL
Mr Marco (06-08-2013)
Well good for you!
Sorry for the late reply guys been working hard and log hours this past month, and noise hasn't resurfaced, however I am changing the Oring this week. I have a good mechanic friend (works on my maxima and he owns a tl so he know all about it). Just so you guys know my RDX is an 07 RDX tech with 44k.
Thank you Mr Marco and DC Models
rockyboy
08-04-2024 10:35 AM
snorf
11-04-2019 06:44 AM
rockyboy
01-25-2016 06:00 PM
