Would YOU consider modifying the suspension IF...
Old Feb 26, 2008 | 02:01 PM
Acura604's Avatar
2024 RDX A SPEC
... you find the ride too stiff? although modifiying the suspension is at a cost both pricewise and performance wise... but what are some cost effective ways to make the RDX drive a bit smoother? larger tires? better shocks? springs?
Old Feb 26, 2008 | 04:07 PM
MMike1981's Avatar
big shot.
if this were the case, buy the lexus.
the 08 is even softer than the 07.
Old Feb 26, 2008 | 04:13 PM
JGard's Avatar
is it? Any way I can swap my 08 suspension from an 07? I want this thing to be more stiff and have less body roll.
then again, I'm coming from an S2000...
Old Feb 26, 2008 | 04:30 PM
MMike1981's Avatar
big shot.
...they retooled the suspension a bit for the 08, to more or less address the concerns of an "overly-stiff" noncompliant ride that the 07 had that some people were pissed about. the 07 was perfect, at least IMO. I think they should have left the truck alone.
if i could go back to the way my 07 was id love to. the 08 def takes corners differently, especialy higher speed on/off ramps, body rolls to much on turn in. steering is a little lighter.
Old Feb 26, 2008 | 05:20 PM
CaSHMeRe's Avatar
... the CaSH ...
http://eibach.com/cgi-bin/htmlos.exe...63786700006504
and they can be bought here ...
http://stores.channeladvisor.com/aut...temid=10259370
Old Feb 27, 2008 | 08:47 AM
MMike1981's Avatar
big shot.
yea...i know about the kit, just not sure i wana go thru the trouble of doing it. If Hondata releases a flash that incorporates the CPE intake, then ill prob get the rims and the spring kit to supplement the entire package.
Old Feb 27, 2008 | 08:54 AM
Acura604's Avatar
2024 RDX A SPEC
actually.. one thing i forgot to do was check tire pressure.. the RDX is a mere 4days old since i drove it off the dealer lot and it's possible the tires are over inflated.
Old Feb 27, 2008 | 09:27 AM
Acura604's Avatar
2024 RDX A SPEC
EDIT:
Just checked the TPMS on the RDX. (note that there is less than 500km on it)
something i should have done way earlier!
here are readings (canadian) ..holy crap! 32psi is about 220kpa.. this would definitely explain the crap ride quality.. numbers are ALLL over the place. Car has been parked for
about 1.5hrs so tires are probably still semi-warm:
252 -------- 260
260 -------- 272
Old Feb 27, 2008 | 10:28 AM
MMike1981's Avatar
big shot.
and there you have it.
Old Feb 27, 2008 | 04:42 PM
cwepruk's Avatar
The TPMS is not that accurate and the numbers do go up when warm.
I pegged mine at 32 psi on the gauge and the TPMS, when cold usually goes from 220-232 depending on the wheel.
Old Feb 27, 2008 | 05:55 PM
Acura604's Avatar
2024 RDX A SPEC
the dealer adjusted it to:
236kpa for front / 238kpa for back (warm)..
as i drove home on the highway, the figures on the tpms did fluctuate a bit per tire but by maybe +2 or so. in any case, it has made a HUGE difference on ride quality.. it is much more smoother.. albeit not a LEXUS or MERC but definitely better than before.. looks like the PDI boyz didn't do their job!
Old Feb 28, 2008 | 07:56 AM
JGard's Avatar
well the pressures will increase as you're driving, particularly if on the highway, because the tires (and thus the air inside) heats up which increases pressure.
Personally, I'd set the fronts a pound or two higher than the rears just because 57% of the vehicle's weight is hanging over those front tires.
Plus, inflating the rears more than the fronts will increase the car's oversteering tendancies. Granted the RDX understeers like a pig, but it's just something to note in case you're not proficient in performance driving.
On another note...those springs. Does anybody know anything about our stock struts? Generally just replacing teh springs with something stiffer gives stock struts more of a workout and thus wears them out more quickly. I'm wondering if there are also replacement performance struts for the RDX.
Old Feb 28, 2008 | 11:33 AM
MMike1981's Avatar
big shot.
judging by the stiffness of the 07 ....i dont think you should worry about harming the struts on the 08.
Cose has the eibach's...if u see this how much stiffer are they compared to the stock 07
Old Feb 28, 2008 | 10:34 PM
06WDP-TL's Avatar
Hondata > *
i love the 07 RDX as is. i dont mind the extra "stiffness", it makes great for handling and my spirited driving.
Old Jul 7, 2008 | 09:40 PM
mikecybergolf's Avatar
Switching it around. Can a 2007 be retooled for a softer 2008 suspension? If yes how much can I expect to pay?
MrHeeltoe
20
Feb 23, 2023 01:54 PM
lanechanger
Oct 13, 2015 10:56 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
adreano17
Sep 29, 2015 08:48 AM
MrHeeltoe
Sep 28, 2015 05:43 PM
