whats next
cams have a decent lope.. i would be curious to see what a bigger one would do though
shivaswrath (01-16-2014)
carbon drive shaft would be nice.. wouldnt mind something that could really handle the TQ.. honestly if you want to make a good improvement i suggest a better TQ converter.. it will give you better response specially with all that HP and TQ we are missing from the slushbox of an auto we have..
Why talking about drive shaft, cams or turbo if the biggest issue of RDX has not been solved yet?? I'm talking about heat soaking. Now we can tune the Flash pro. If we would be able to bring down the temp on the IC it will let us tune our comps more aggressively. This would be the biggest upgrade right now.
I vote for asking Richie to accelerate the development of the liquid-to-air set-up for us.
not an SUV ...a Big Hatch
ive had no issues in extreme summer weather (110+), repeatedly. ETS and manifold gasket work very well.
if I ever repeatedly floor it with the hood open and not traveling anywhere... maybe i'll be in trouble.
carbon shaft will improve mileage, acceleration, possibly braking distance, etc.. and shouldn't have a prohibitive R&D cost.
our drive shaft is pretty light to begin with.. sean church states in this video its around 30/35 lbs
carbon fiber would be about 15/20lbs due to metal parts being added.. so that works to about 10hp gained due power loss.. a good torque converter can give you that maybe more and probably cost less.. 1000$ drive shaft vs 600$ tq converter..
BigHatch (01-08-2014)
from ATI
We are a GM based v8 racing company; we have no support or offerings for import transmissions.
The transmission if you can find someone to build one that will handle HP it will be the same cost as a rally cross manual transmission, they are 25K.
If you do find a transmission the converter selection will only be OEM components and never perform properly. Unfortunately this is the cold fact. Be not falsely told of “new” or hardened parts I have seen even in the v8 overdrive world a “hardened” part is only an OEM part that has been heated. This might make a factory part a small % better but will still brake and most of the time the heat treat was done incorrectly and the part is brittle.
IPT http://www.importperformancetrans.com/index.shtml will beg to differ.. i know they would need the existing tq converter to rebuild since they dont have cores but they rebuild it and its proven..
it looks close... http://www.ebay.com/itm/05-12-Acura-RL-AWD-Carbon-Fiber-Drive-Shaft-OEM-LKQ-/190998397618?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AAcura%7CModel%3ARL&hash=item2c786442b2&vxp=mtr#ht_3077wt_959
for 390$ its almost half tempting to see if it does fit.. you could always resell if later if it doesnt.. wonder how light it really is in comparison
here are another two, a little bit cheaper:
http://www.ebay.com/itm/05-Acura-RL-Propeller-differential-drive-shaft-rear-40100-SJA-000-OEM-/230936145907?pt=Motors_Car_Truck_Parts_Accessories&hash=item35c4ddeff3&vxp=mtr
http://www.ebay.com/itm/05-12-ACURA-RL-DRIVE-SHAFT-PROPELLER-SHAFT-40100-SJA-E02-9917-/281230756335?pt=Motors_Car_Truck_Parts_Accessories&hash=item417aa8c9ef&vxp=mtr
someone buy one and compare =)
I just posted above, if we do this, it's about $700 for fresh set over to get reground...is that the only R&D cost, or are we talking literally a new set of cams (that might be cost prohibitive for a company to do).
Dustin Spencer (dustin@briancrower.com)
Add to contacts
1/07/14
To: the_wrench116@hotmail.com
From:Dustin Spencer (dustin@briancrower.com) You moved this message to its current location.Sent:Tue 1/07/14 5:01 PMTo: the_wrench116@hotmail.com
It’s about 65K to do the tooling to make the cam core so we just have to justify the demand before committing introducing a new cam line.
Thank you,Dustin Spencer
Brian Crower, Inc.
161 So Marshall Ave
El Cajon CA 92020
From: joshua fletcher [mailto:the_wrench116@hotmail.com]
Sent: Monday, January 06, 2014 1:50 PM
To: Dustin Spencer
Subject: RE: K23
ok that sounds good. what kind of interest would it take to make a production run at this? albeit a small run but a run none the less.
Subject: RE: K23
Date: Mon, 6 Jan 2014 13:45:28 -0800
Joshua,
Unfortunately we do not have any cams available but we can regrind your factory cams for $495 and 2 week lead time.
Brian Crower, Inc.
161 So Marshall Ave
El Cajon CA 92020
Sent: Thursday, January 02, 2014 10:26 PM
To: info@briancrower.com
Subject: K23
Sent from Windows Mail
hello my name is joshua fletcher and I am the proud owner of an 08 Acura RDX Tech with SHawd. I have a majority of the equipment available for it from the aftermarket and am interested in what is next. I was hoping you would be willing to develop a set of cams for our under appreciated platform. thanks for your time sincerely Sgt fletcher
there are plenty of stage 2 and 3 cams out there for K series motor.. its just a matter of matching which would work best
They are not compatible. Rdx's do not have 3 lobe cams. They have single on the exhaust and two on the intake. k20a3 and the k24a1 share similar cams. I believe people have already tried to compare the two when the rdx was first released. No go.
honda CRV is a dual lobe setup they make cams for that i think
http://store.skunk2.com/engine-tunin...camshafts.html
no it doesnt read it again
Product Description
Item Number: LS086
Condition: New
Price: $255 Shipped in continental U.S.
Description: Skunk2 K20A3/K24A1 Turbo 1 Camshafts (Part# 305-05-0265)
*These cams are NOT for the RSX Type-S (K20A2) or '06+ Civic Si (K20Z3) style engines. These are for 02-05 Civic Si and Accord/CRV style engines without the full VTEC on the exhaust cam.
Product Description
Item Number: LS086
Condition: New
i sent them an email too.. just to see
Skunk2 cams suck. Fast ramp rates cause tensioner failures. The wear fast as well. I've personally seen grooves in the lobes and it wasn't from oil starvation either. Not even 10k miles on them.
Me personally none. I refuse to run any skunk2 parts. Countless have failed via skunk2 cams. Browse over on k20a.org about their quality. They've made good power but don't last. Cheaper Chinese metals are used in the cores.
Any thoughts on a FMIC setup? That would help temps significantly. Also you would want to stick with a cam design for turbocharged engines due to longer valve duration. N/A cams could possibly degrade performance rather than upgrade it.
not much room for piping a FMIC.. plus youll get some turbo lag too
