Tire Size 255/50/18R
Is anyone running a 255/50/18R tire on the stock RDX 18" wheel. I purchased these because the supplier didn't have the stock size available at the time of purchase. They are Nitto brand and are approx. the same height but have a section width about 3/4" wider than the stock tire. I want to be sure that they don't rub any of the suspension parts.
Yokohama has a new tire, the Envigor, sold by the TireRack, in this size. Currently advertised for $150/tire at the TireRack.
It's supposed to give as good tire wear and traction, but a more comfortable ride.
TireRack has tire circumference measurements that help assure you that don't throw your speedometer/odometer off.
If I remember right, the Envigor in this 255/55 18 size was very close to the circumference of the OEM Michelins.
When I finally need new tires, I'll probably buy these Envigors.
Yeah, Yokohama makes a great tire, but just for kicks, checkout the Nitto 255/50/18 - 420S on the Discount Tire Direct site. The tread pattern is awesome and the reviews are great. The circumference and sidewall height is almost identical to the 235/55/18R that is stock on the RDX. Just about .79" wider at the section width.
nuldabz
09-03-2015 05:49 PM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
