Looking for FlashPro RDX beta testers
#163
Yes, and depending on your model year, it may come with a base map for an intake and / or fuel injectors as well. Hondata also told me that while the files themselves are not directly compatible between all years, you can manually cut / paste the fuel tables from from one tune to another to gain the same benefits.
#164
Thanks for the replies. I have an unmodded 07, do you request a base map for intake or injectors or does it just come with it depending on the year? I would rather it came with just the base reflash map and I can make changes as the modifications progress.
#166
I believe the maps are included in the Flashpro software that you download from Hondata. You should be given the opportunity to choose which vehicle(s) you want to get flashes for, but regardless of what you choose the cable will only work with what it has been set up for.
#168
PM me if you need a reply
Been meaning to post these up a while ago...
Power mods: Hondata flashpro, C-PE intake, 3" catless exhaust, ETS TMIC, 600cc Deatschwerks injectors, P2R intake gasket
They told me over the phone that they could get 320tq to the wheels with my mods. Seemed like the tuner on shift that day didn't care.
#170
He has a DP...at least I assume by the '3" catless exhaust'. Should be able to get more power out of that, but it really depends on the turbo's capabilities at this point. Looks like you boost is hitting 14 lb and dropping to 12 by redline, which I think is about the same as the basic Hondata flash. Now that you have injectors, put that turbo to work and see if you can get better numbers. I'd love to see one hit 300 at the wheel. Or at least 275 for AWD.
#172
The wheels are 20x10 +40 Gianelle Yerevans.
I just uploaded more pics of the car at https://acurazine.com/forums/members/infamousjamous-297615-albums-2011-15927/.
bluecarbonfiber (05-30-2014)
#173
WTF?
forgot to ask you have any sound clips of the exhaust? i am debating on if i want to do a catless or have a cat for the DP.. I am hoping it wont have highway drone.. or sound raspy trying to stay away from that on the rdx
