K23a1 Build
Old 07-10-2014, 01:10 PM
  #161
KenB350z's Avatar
They look pretty much the same, maybe just the tension (internal spring) at high rpm, I'm assuming is the difference. I'm hoping shortly after everything is done I can get in to schedule it to be tuned.
bluecarbonfiber (07-10-2014)
Old 07-10-2014, 08:20 PM
  #162
KenB350z's Avatar
New wheel and tire setup: TSW Nur 19x8 +35 w/ Michelin Primacy MXV4 235/50r19.
Old 07-10-2014, 08:25 PM
  #163
KenB350z's Avatar
Valve adjustment.
Old 07-10-2014, 11:16 PM
  #164
KenB350z's Avatar
It started up nicely, well have video up soon. The turbo was a bit loud because we didn't have the intercooler on at the time of the video.
Old 07-11-2014, 06:14 AM
  #165
KenB350z's Avatar
The following 2 users liked this post by KenB350z:
bluecarbonfiber (07-11-2014), DRR98 (07-14-2014)
Old 07-11-2014, 07:59 AM
  #166
KenB350z's Avatar
This shows the car at idle, sounds and runs like stock. He was checking for codes, only codes he says in video. They were just for things that were unplugged. Now just need a tune!
Old 07-11-2014, 08:06 AM
  #167
KenB350z's Avatar
He told me that the JDM intake has to go if I wanted a proper tuned.
Old 07-11-2014, 09:05 AM
  #168
FLETCH
TheWrench116's Avatar
tell them to stuff it. keep your sexy CF. do you have injectors? you need to list your parts in your signature or maybe start a tread to have built rdx parts list and combos and power made ? just a thought.
Old 07-11-2014, 09:22 AM
  #169
TheNewAcura's Avatar
I'm excited for the dynos
Great Build
KenB350z (07-11-2014)
Old 07-11-2014, 09:53 AM
  #170
WTF?
bluecarbonfiber's Avatar
curious why you went 235 50 instead of a 255 40 or a 245 45??
Old 07-11-2014, 10:22 AM
  #171
randeez's Avatar
shed some weight? I think he had 275s on 20x10 before
or hoping for AWD donuts more then likely
Old 07-11-2014, 10:43 AM
  #172
FLETCH
I feel like a kid
did you get a tune yet did you get a tune yet did you get a tune yet
yeah sorry I need to see how well this stuff works as a system. and good luck!!!
Old 07-11-2014, 01:14 PM
  #173
KenB350z's Avatar
Haha, Yeah! I really want to keep the Intake, but if its going to hurt hp numbers I'll have to put in on the shelf and keep it for car shows. I have DW 800cc injectors and DW 200 fuel pump. I was told to hold off on installing the injectors until I get closer to getting it tuned. Oh yeah, I will make a BIG post on the parts list and dyno results for sure!
Old 07-11-2014, 01:21 PM
  #174
KenB350z's Avatar
The tire is clean and OEM looking and the 235 kept me right around stock height. If the SH-AWD works like it should, I will be able to get off the line quickly!
Old 07-11-2014, 01:23 PM
  #175
KenB350z's Avatar
Yeah, maybe I lost some weight with this setup. Don't know about donuts haha..
Old 07-11-2014, 01:25 PM
  #176
KenB350z's Avatar
Talking
I feel like a kid
Coming soon!!
Old 07-11-2014, 02:28 PM
  #177
exist12's Avatar
keep an eye on the af with stock injectors and your setup. I have flashpro, intake, ets intercooler and exhaust and my duty cycle is already at 95%.
Old 07-11-2014, 03:13 PM
  #178
WTF?
wasnt sure.. i been looking at a 255 40 since thats the closest to stock diameter per 1010tires.com tire calculator but the weight is 5lbs more then a 245 40 i want to have that cornering ability.. im sure with going down to a 19 and adding those big brakes you probably equalled to what you were with the 20x10s
Old 07-11-2014, 03:50 PM
  #179
FLETCH
Those brakes though!!!
Old 07-11-2014, 04:34 PM
  #180
protoRDX's Avatar
Do you use the reflash map, intake+DP map or custom tune?
Old 07-11-2014, 04:49 PM
  #181
KenB350z's Avatar
YEah, I was told not to get on it at all until it was tuned(with the mechanic looking straight in the eyes).
Old 07-11-2014, 04:55 PM
  #182
KenB350z's Avatar
Here are the specs of the OEM 18 w/tire and TSW 19 w/tire. I will have to weight the 20's later; however, I'm sure they weight a lot more then both of these. The OEM brake caliper weight more then the Ksport brake caliper, but the Ksport rotor weight a bit more then OEM. So, I think the brakes pretty close to even weight. Give or take a few lbs.
OEM: 18x7.5" +45mm
Tire: 235/55r18
Tire diameter: 28.1"
TSW: 19x8" +35mm
Tire: 235/50r19
Tire diameter: 28.3"
Old 07-11-2014, 04:58 PM
  #183
KenB350z's Avatar
Currently use reflash map, intake and DP, with air mass turned off. So, I guess it's a little custom.
Old 07-11-2014, 05:35 PM
  #184
WTF?
OEM: 18x7.5" +45mm
Tire: 235/55r18
TSW: 19x8" +35mm
Tire: 235/50r19
awesome stuff to know =)
Old 07-11-2014, 08:02 PM
  #185
FLETCH
hahahahah
and hows that working out???
Old 07-11-2014, 08:45 PM
  #186
KenB350z's Avatar
I felt like that guy from New Jack City named "Pookie", but I kept my word and drove like a granny the whole way to work. But oh boy did I want to just
Old 07-11-2014, 09:18 PM
  #187
not an SUV ...a Big Hatch
BigHatch's Avatar
Man...you got all our mouths watering!!
I mentioned your build to a local race shop when I was in getting some fenders rolled on a new to me car...
They are a hondata dealer too, and seemed pretty interested.
Many will follow these footsteps! So exciting!
Any rough estimate on parts cost so far?
The following 2 users liked this post by BigHatch:
KenB350z (07-11-2014), protoRDX (07-11-2014)
Old 07-11-2014, 10:01 PM
  #188
KenB350z's Avatar
I'm hoping I can get to Humble Performance monday and get it tuned, but we'll have to see.
I will add everything up and post on the main page a list and price of all engine parts and labor after the tune. Wait, I can't do anything until after I get my AEM Electronics Air Inlet Temperature Sensor in, and a pipe made. Damn...
Old 07-12-2014, 12:30 AM
  #189
KenB350z's Avatar
Oh yeah, I went with these plugs from the Acura dealer.
Old 07-12-2014, 01:37 AM
  #190
exist12's Avatar
How did you shut off the mad hondata told me there was no way to run speed density.
BigHatch (07-12-2014)
Old 07-12-2014, 02:33 AM
  #191
KenB350z's Avatar
You will have to talk with your tuner about it. My tuner just went off the map, I couldn't run my JDM intake with it on, it was cause it to go into limp mode at WOT. This was done with flashpro.
Old 07-12-2014, 02:40 AM
  #192
BigHatch's Avatar
should be able to tune for the intake too though, you think?
Old 07-12-2014, 02:50 AM
  #193
KenB350z's Avatar
Yeah, I think you can tune up to 4". I'll have to listen better or video the next tune they do.
Old 07-12-2014, 10:29 AM
  #194
exist12's Avatar
I was thinking of trying to run blow thru when I install my RBC manifold
Old 07-12-2014, 02:48 PM
  #195
KenB350z's Avatar
Yeah, same here. I'm trying to find a shop that can make me a one piece pipe with a 50mm Tial adapter.
Old 07-12-2014, 04:03 PM
  #196
Haré romel's Avatar
Hi, I was dream this build long time, good luck. lets see you feel at rev limit.
KenB350z (07-12-2014)
Old 07-12-2014, 07:05 PM
  #197
KenB350z's Avatar
It was the rear O2 sensor that was turned off not mass air.
Old 07-12-2014, 07:43 PM
  #198
KenB350z's Avatar
Waiting for the engine to cool so we can put these puppies in!
Old 07-12-2014, 10:24 PM
  #199
KenB350z's Avatar
Old 07-12-2014, 10:30 PM
  #200
KenB350z's Avatar
Quick Reply: K23a1 Build
