BC Suspension- RDX Coilovers
#81
#83
#85
Hey Bu what website did you go on to check the prices $$$ the one I went on showed there products for $999 ??http://bcracingsuperstore.com/
I will take BCRacingSuperStore price $999
#86
Fender roller are easy to find, some people advertise it as a service on Craigslist. If you are near the Bay Area (northern California) you are welcome to use mine.
BC told me these should be around $1,000. Check their quote in earlier posts.
#87
'06 RL Tech
#88
I bought the roller from another forum for around $180. They are not that expensive.
Are you rubbing right now with your wheels? If not, then I wouldn't worry about it.
#89
'06 RL Tech
#90
Copy cat shinobi
Hey guys if you were onboard with me in my thread in "suspension : 10 ppl needed 4 coilover development(KSport)" I highly encourage you to join RRockets if you haven't already. Thx guys!
#91
Kaze, thanks for the kind words.
FYI, this is BC Suspension's creation. I have nothing to do with it, except I asked them to build it for us.
I told them I would pony up my suspension for measurments and then be a beta tester for them.
They got it 99.99% good right out of the gate. I already provided my feedback and will keep you all posted as to the release date. I have also asked them to take some pre-orders.
Now we have to make a rear swaybar that is stiffer than stock and preferably adjustable. Who is game?
#92
'06 RL Tech
I want this so bad. Both! It'll be summer before I can do anything. We're going to Florida with my daughters softball team this summer, so far. My toys have to wait. I'll watch and drool.
#94
Copy cat shinobi
^2nd that, curious now.
Altho, I've noticed with the KSport CO on my still being built weekend warrior that presetting the damping will affect ride from stiff to cushy. I set mine to mid(18) lots of feedback, any higher bumps in the road would move loose items in the glovebox and center console..lol.
Pretty sure that BC catered that aspect, and other forum members said that KSport vs BC that BC had the least punishing ride on the streets. And more bang for your money. If you are lowering the rdx your gonna want to avoid potholes and speed bumps anyhow.
Really looking forward to this!
#96
2/26/2012 Driving impressions:
As stated before I raised the rear by 1 inch, and softened the rear suspension by 2 clicks. Went for a sprited drive in the back roads (tight turns of 15 mph to med speed 45 mph). The rear still feels stiffer than stock. I was attempting to bring the ride quality (read that as comfort) closer to stock, I think I need to be more aggresive on softening the back up. The ride over rough roads is stable. The "hoping" that usually happens in corners on rough roads is greatly muted, I will need to mess with the adjustments more and conduct further testing to see if I can get ride of it all together. The dampening makes the car feel more stable, and the center gravity being lower is helping a ton in making it handle better. The car now gives you confidence to "throw" it into corners, where before I could feel it being top heavy. If you have good tires (I don't yet) I think you will GREATLY benefit from this suspension set up. It is still very forgiving, I on purpose tried to get the car out of shape, but you can gather it back up very easily (almost all the work is being done by SH-AWD, thank you Acura ), these shocks give you better and quicker feedback so you can react even better and enjoy your car more. The understeer was reduced due to raising the back, but it is still there. We really need a bigger swaybar in the back of this car. Anyone has the capability of making one?
on a side note, it is much easier to get in and out of the car now!
The brakes on this car are simply weak, there is no other way of saying it. Mind you I have slotted rotors, ceramic pads, SS lines, and ATE "Blue" brake fluid. It is hard to justify a BBK for what is mostly a commute car, but if it is your only car AND you want to track the car then I would highly recommend a BBK. The suspension is stiffer than stock, so the car does not dive as much under heavy breaking and with my simple mods the braking is a LOT better than stock. Still...not a strong point for this car...
I have nothing but positive results from BC's set up for our RDX. They are simply spot on and have made the RDX into a very desent canyon carver. The car feels more like a GT than a SUV.
Once I rolled my rear fenders there was no more rubbing in the rear. The front fenders can't really be rolled, I do rub in front (remember I have 25mm spacers) but it is the fender liner and not the fender. In fact it is rubbing the "prodruding bolts" that hold the fender liner to the fender!!!
I wanted to possibly lower the front a bit more (1/4 to 1/2 inch), but I'm sure it will rub even more. I'll have to figure it out...
Let me know if you have any questions, or requests.
InfamousJamous (02-29-2012)
#97
Copy cat shinobi
^ Anti-roll bars, I am working on a few solutions. Approached a few manufactures as a community and not as a single person this time. Im not promising anything.
#102
'06 RL Tech
#103
Hello Gang,
Great news, the "specs" are set. I spoke with BC Suspension and they have the final numbers/spec to go for production.
Our RDX production run is behind two other cars, they will email me once they have a more accurate date (read that as 30-45 days before production).
As an FYI, BCRacingSuperStore is NOT BC Racing. They are their distributor. The reason I mentioned this is that BC Racing will take your orders (Acurazine members) directly and have the coilovers shipped directly to you from the factory. It will be the fastest way of getting these once available. I will keep you all posted once they tell me they are available for shipping.
Cheers.
Cheers.
#107
GREAT NEWS, production has commenced.
They will be ready to ship by 1st of April.
Further modification to the rear height adjuster will allow you to use the stock bolt from your car, so no further modifcation is needed.
Asked them to confirm the price and give specific instructions on how to order, so you would get it directly from the factory (and as fast as possible).
There is ONE set ready to ship right now! First come first serve. Please post here on Acurazine and I'll get you connected to the right folks at BC Racing.
Cheers.
Cheers.
#108
Big Hatch,
Please take a look at the entire thread, I have many pictures and even an extensive write up on how to install.
This coilover kit includes:
Front Strut
Front Spring
Front Spring Top Purch
Front Swaybar Rod
Rear Shock
Rear Springs
Rear Height Adjuster
Adjuster Tool (for height adjustment)
Both front and rear will be adjustable for Compression/Rebound (with one knob), and Height.
Cheers.
Front Strut
Front Spring
Front Swaybar Rod
Rear Shock
Rear Springs
Cheers.
#109
Cheers.
Cheers.
#110
tonyquinto has dibs on the first set, congrats. I'll PM you shortly.
BC did confirm the price at $1K, plus ground shipping. They will be shipping the initial sets direct from the factory expedited, that should save you 2-3 months vs. being shipped by boat (containers). BC will pick up the difference in shipping for Acurazine members.
Cheers.
Cheers.
#111
^ By boat? Made in China?>:
#112
not an SUV ...a Big Hatch
Big Hatch,
Front Strut
Front Spring
Front Swaybar Rod
Rear Shock
Rear Springs
Cheers.
Front Strut
Front Spring
Front Swaybar Rod
Rear Shock
Rear Springs
Cheers.
#113
Man, the 1 day I am out of town... & Rotary Rocket posted BC had 1 set available.
I am Sad & need an iPad 3
BU
BC probably made in Taiwan.
BU
#114
Mr. Marco,
They are made in Taiwan. I have to tell you the quality is very impresive. Has a bit of a "bling" factor (Black and Gold), not a fan of the gold, but a HUGE fan of the anodized black.
You can't see them since they are under the car anyways.
We use them in our race cars (USTCC), if they live under the abuse of racing the street will not be an issue. They have also been in business for quite a while, they have a good reputation on the street as well.
You could always wait a couple of months and get the feedback from other members before pulling the trigger.
Mr Marco (04-05-2012)
#115
As a rule of thumb any 10mm adjustment up or down on the rear height adjuster will result in 1 inch change in the height of the rear of the car.
#116
Gang,
The support you have shown for this company is great, I've received lots of PMs.
Please feel free to call BC Racing directly at 321-206-6381.
Be sure to mention you are from "Acurazine", this way they will pick up the extra shipping cost. As mentioned production has started and they are looking at begining of April to ship out your suspension.
I live in California and got mine in two days!
Once they have taken care of your (Acurazine) orders, then they will put it on their regular rotation to be broght in via container/ship. Due to the timing of "filling up" of a container, etc. this type of shipping will take 2-3 months.
If you are interested please be sure to call them and place your order directly with BC Racing at the number listed above.
I would be more than happy to answer any questions in regards to installation, performance, or whatever else you need to know about these coilovers.
Please note, I have no interest in, or in anyway am associated with BC Racing. They just happen to be nice enough to build our beloved RDX some coilovers.
Cheers.
Cheers.
BigHatch (03-07-2012)
#118
I don't know, it seems to me you would have at least 'till end of March/begining of April sicne that is when they will first be ready to ship out. If you are not ready to pull the trigger by the begining of April then I would say give them a call and see what their production numbers look like.
They have been super cool. I was up front with them at the begining and told them it was not a huge market as I did not want to mis-lead them. Their mentality is that once you try their product you become a loyal customer and as you change cars in the future you will continue to support them. Totally makes sense to me.
I really like this company.
Cheers.
Cheers.
JMJ3rd (03-08-2012)
