09 Hondata + CP-E dyno numbers
Old Jun 25, 2010 | 05:16 PM
Gmedalion's Avatar
I just put in the Hondata. Butt dyno likes and this is how they should have made the car. Here are the numbers. Basic run was with just the CP-E and the other pull was with the Hondata. This was done on a Land and Sea dyno. Sorry if you can't see the numbers.
Try this to see it better http://images17.fotki.com/v529/file6...25/Pic0001.jpg
http://images21.fotki.com/v839/filey...25/Pic0002.jpg
http://images23.fotki.com/v857/filer...25/Pic0003.jpg
Old Jun 25, 2010 | 05:47 PM
gungho_15's Avatar
Numbers look good. Whats the serial number of your ECU? I dont see that 2009 are available to be reflashed on the HONDATA website. I have a 2010 and want mine done, but they told me they might not be offering this upgrade.
Old Jul 3, 2010 | 10:17 AM
brianko's Avatar
Call a HONDATA dealer with the numbers off your ECU (the '09 is RWC-27A, I believe...). Even though it's not listed on their website, a tune for the '09 is available. Might be the same for the '10, you'll have to check.
Old Jul 3, 2010 | 10:36 AM
mrgold35's Avatar
mrgold35
I'm having a hard time reading the graph. Can you post the before/after HP/TQ and rpms for the peak. I have Hondata with K/N drop in filter on my 08. The RDX is a lot easier to drive with the extra power.
Old Jul 4, 2010 | 11:41 AM
Gmedalion's Avatar
You can click on the links that I posted under each photo for a better view of the graphs, let me know if you cannot see them
Old Jul 6, 2010 | 09:42 PM
BigHatch's Avatar
not an SUV ...a Big Hatch
lol... they come up a lil smaller even.
Old Jul 7, 2010 | 07:47 AM
wspy's Avatar
2008 Acura RDX
Gmedalion, please repost you pics with a greater resolution! They are currently too small to see, and the links are even smaller
Old Jul 21, 2010 | 03:20 PM
Gmedalion's Avatar
Sorry guys,
Go to this link
http://public.fotki.com/Gmedalion/rdx-dyno/
Click on the photo and then at the bottom of the photo it says "Get Original Uploaded Photo" in blue and you should be able to see it then.
Let me know if you're having problems.
Old Jul 22, 2010 | 08:11 AM
wspy's Avatar
2008 Acura RDX
Thanks they work great now!
Wow!.. This is some significantly important info here!
These charts show that the CP-E intake, as a mod by itself, has quiet a rich and very safe airfuel ratio (in the 10s) while giving some power increase (as known from previous experience and not these charts)!
Some people were suggesting that CP-E made the power that it does by leaning the A/F ratio and be that as it may the resulting ratio is shown to be still very conservative and safe. So you can imagine how rich the RDX is from the factory!
That being said, it was also suggested that combining CP-E with Hondata may be leaning towards being unsafe, but here again we see that the A/F ratios are very safe (in the 11s) which not only give the advertised increase in power but should also give an increase in mpg. Plus the fact that Hondata already did this test when formulating their flash!
Great stuff!
The question now remains as to what will happen (A/R ratio wise) with the addition of a downpipe that will eliminate the primary cat, freeing up exhaust gas flow, increasing power abundantly, and further leaning the mixture?! It was shown somtime ago that with a stock ecu, custom downpipe (no cats), and an intake, the a/fs were hovering around the 11.6 area.
Hmmm.... adding the flash my put it in the High 11 low 12 region.... still safe but not as
Old Jul 23, 2010 | 03:46 PM
Gmedalion's Avatar
I wonder if it will be safe if I add an exhaust or DP next.
Old Jul 25, 2010 | 11:43 PM
fopaul13's Avatar
wspy, so if i'm reading the charts correctly, since we're a-ways from 14.7 from an AFR perspective, it DOES seem safe to run CP-E + Hondata together. Is this true?
Also, I assuming a K&N Typhoon would run similar to the CP-E, is this safe?
Old Jul 25, 2010 | 11:58 PM
SinCity's Avatar
What AFR range do you want to be in on a Turbo motor?
Old Jul 28, 2010 | 01:56 PM
wspy's Avatar
2008 Acura RDX
Anywhere from 12.5 to 10 is good
Old Jul 30, 2010 | 11:46 PM
bpayne42587's Avatar
5th Gear
Nice numbers
Old Aug 9, 2010 | 10:39 PM
SinCity's Avatar
I wonder what the tube diameter around the CPE is? The K&N Typhoon is around 74mm which is same as stock.
Old Aug 10, 2010 | 07:07 AM
wspy's Avatar
2008 Acura RDX
Yes and yes, an afr in the 14.7 to 13's is ok when you are off boost just cruising around town, when you go on boost you want the mixture richer thus the 12.5 and up.
Both the intakes give an increase in power; I believe the CP-E produces a little more because it was 'tuned' to lean out the mixture a little more thusly producing more power.
Reguardless of the diameter of the pipes employed both systems produce a power increase
08KBP_VA
Oct 22, 2019 01:55 PM
emailnatec
29
Sep 28, 2018 04:27 PM
jterp7
3G MDX (2014-2020)
Feb 3, 2016 08:34 PM
InFaMouSLink
Oct 30, 2015 09:43 AM
eastcoastguy
Sep 23, 2015 06:29 AM
