Rear Brake Caliper Torque
I am replacing rear calipers on my 07 RDX. These calipers have a bolt just under the bleed screw and the manual says, "Do not loosen this bolt" (see pic, blown up in circle) and shows no info on the bolt, nor torque. That bolt on the new caliper is loose. Any idea what it is and the required torque? Thanks
Can you confirm what the correct torque is for front rotor bracket bolts? I’ve seen various answers and am confused right now. I believe the service manual says 101ft lbs, others have said 80. This is for an 07rdx
dP- (04-27-2022)
RDX guy
09-12-2017 09:46 PM
01-16-2005 01:46 PM
