rdx tune up?
Diff fluid change only when code 6 appears on the MID, I forget the code for transmission. I don't follow the computer, from past experiences with Honda A/T's I change the fluid more often, I usually do it every 20-25K (KM's btw) which comes out to about every 3rd or 4th oil change.
op, just follow MID. mau is correct with the codes. ive always just followed MID.
mau, just a ff up and totally unrelated question: was it you who used to take sunoco 94 and had emissions problem light coming on? ive had the same issue (eg. petrocan 94 - check gas cap). went away with shell 91. any idea what happened? or did you just let it go? thx
haole kama'a-ina
OP, do you mean 48k kilometers or 48k miles?
If it is at 48k miles the trans fluid change is due soon (possibly overdue) and the rear differential is very far overdue.
The MM should have called for rear diff initially by 12k to 20k miles and again around 35k to 40k.
Even if it's 48k km, you should have seen a code 6 by now.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
