Question for those that have the ETS IC
Did it come with a separate screw for the MAP sensor that plugs into the corner of the IC? I'm talking about the little 8mm screw, not any of the 10mm.
Thanks~
Thanks~
So it turns out the MAP sensor bolt hole on the ETS IC fits the same size as the rest of the bolts that hold it in place, so I just went and got the correct length / size bolt from Ace for 60 cents.
For another 60 cents I bought a large, flat rubber washer and trimmed it to fit between the recirc valve and IC. I just don't trust a metal to metal connection to hold pressure. Maybe it's just me?
Still not sure if the IC comes with these two things normally, but just in case I figured I'd post up my cheap and easy solution.
navtool.com
31
11-16-2015 08:30 PM
DerrickW
11-15-2015 05:52 PM
