new Calif. oil change guidelines
Recently California has embarked on a campaign to reduce the oil change frequency and reduce environmental impacts from disposal.
This website:
http://www.checkyournumber.org/#
suggests that for the RDX 7,500 M is the appropriate oil change frequency. My car is always due at around 5,000M or 3 times per year. I always felt 5,000M was excessive especially for synthetic. Now my opinion is vindicated. My driving is half city/highway with some traffic.
The frequent oil changes recommended by Acura seem to be based on revenue generation.
What has been your experience with RDX oil change? Especially the DIYs in this forume?
This website:
Your opinion is based upon what? what you wish to be true?
And if this were really the case (revenue generation by Acura), why would not every other car manuf do the same? With the use of the oil change reporting software on current vehicles, you will actually find that every manuf and every model now reports a different oil change interval, again, based additionally upon the conditions under which the vehicle is driven.
If you are thinking that the oil interval for your RDX is short, you should have seen the (short) interval reported for my 2001 Z28 when my commute was 3 miles (one way), especially in the winter when it was -10 degrees.
Just remember the RDX is not a 4-cylinder Civic, its a TURBO, with a specific horsepower output per Liter greater than was once possible with race engines.
---eof
I take it back - the site suggests 15K mile oil change intervals for a 2010 series 7 BMW. I have read that under some conditions, the BMW MID (maintenance indicator display) can also report this oil change interval. I am not certain that I would follow that interval for myself (if I could afford to buy a BMW).
"However, you can trust your vehicle’s maintenance system in your dashboard to tell you more accurately [than the referenced web site] when you need a [oil] change."
And also: "If you do drive in any one of these conditions in a typical week, you are driving in severe conditions,..."
"Extensive idling OR in stop-and-go traffic
Cold weather, less than 10 degrees
Extreme heat, more than 90 degrees
Extreme humidity
Repeated short-distance trips of less than five miles
Towing a trailer or hauling heavy materials"
Seems to me that if you are driving 50% city, then you are driving in the first SEVERE condition, in the list above, from the web site that you have referenced.
My RDX is driven under ALL of the severe conditions, except for the TOWING, all of the time, except for vacations (highway travel). Hence, I use oil change intervals even shorter than the RDX MID recommends.
mada51589
05-03-2022 08:54 PM
HydrasunGQ
09-14-2015 10:14 PM
