does oil filter needs to be changed evey oil change?
If you read the manual, it looks like you can do it every other oil change, but probably most people still replace the oil filter each time they put new oil. replacing oil filter is a bit more messy than replacing oil, so I was wondering if I can drag it out
on the rdx its far from a mess, I make more of a mess draining the oil (missing the pan lol) then removing the filter and its way too easy to replace on the x.
On my prelude and I bet your CL it sits in such a tight location you can actually burn your hand getting to it.
Either way, I change the filter on all cars at every oil change. I'm sure if you use a good quality filter you don't have to worry about changing it but with honda filter I wouldn't.
well, when I changed it on RDX it was easy to drain the oil, not a dropped spilled and hands clear, but when I unscrewed the filter, oil came pouring on my hands and it made a mess. I am glad I only slightly warmed up the car... yeah, honda filter is nothing special, I was thinking of getting Mobil1 and change it every other oil change, which is what owner manual recommends.
btw, do you need to fully warm up the car before changing oil? I think it just needs to be slightly warm(thats what I did), this way it drains faster, but otherwise if you just need to let it drain a bit longer.
its so easy to change oil on RDX, I can't believe it! Besides, I am doing it properly! I've got torque wrench and all... Last time my Acura dealer tightened drain plug way more than 29 lb/ft, bustards, and they also charge you $80 for oil change, it cost me $30 and 30 min of my time (well, not really, when oil was draining I went doing other things.)
Speaking of my CL, i need to get ramps, and then I am not sure if I can easily remove the filter. I change oil on CL once a year, so its not a big deal. But on RDX, my wife drives so much... it needs oil change every 3 month. I'd be broke if I had to go to the dealer each time.
Yes I always change the filter during an oil change.
Originally Posted by Briar
My take on this - after you take a shower do you replace your underwear? Same difference in my eye.
Curious question...
Before buying my RDX I obtained a Carfax for my trade. I was surprised to see every service visit was on the report - even oil changes!
I guess what I'm saying is I found out a Carfax report can help you or hinder you in the buying process.
It sounds like if you change your own oil you save *A LOT* of money, but has anyone considered the trade-in ramifications in this situation?
Is there any value in being able to prove you did the maintenance and did it right?
I'm aware Acura dealer mechanics are fallable, but I think they are predominately better than the average Acura driver at the same tasks probably because they have most of the right tools and data for the job.
Lastly, does a lease make any difference? If you're going to get rid of the car after a few years is maintenance less important since you may not have to deal with the problems that can happen later on?
Originally Posted by STLBill
Curious question...
On top of that, I save $50 each time I change oil myself. It takes me the same amount of time that I would have spent driving to the dealership and waiting for them to be done.
I don't think those monkeys have ever touched my car without screwing something up. It was easier for me to just put a compressor in the garage than deal with them.
mada51589
05-03-2022 08:54 PM
